I want to participate in GSoC from RTEMS
Daron Chabot
daron.chabot at usask.ca
Thu Mar 20 06:32:31 UTC 2008
Madhusudan C.S wrote:
> + The user writes an application and configures many
> tunable parameters including the nanoseconds per
> clock tick.
> Fine understood.
> + The BSP's clock tick driver uses this to program the
> hardware.
> "This program" confused me a bit. Please help me. Is it the program that
> I have to write now or user's application??
"program the hardware" means just that, configuring a BSP's time-keeping
hardware. This process might involve setting a counter's frequency
and/or interrupt generation rate (i.e. the BSP's clock "tick" rate) ,
for example.
> + In RTEMS prior to 4.8, all time was based on the "clock tick".
> When a tick interrupt occurs, the interrupt handler calls
> rtems_clock_tick to "increment the time by the configured
> nanoseconds per tick"
> + In 4.8 and newer, the same use of tick but now we can
> ask the BSP for "nanoseconds since last tick" and get a
> more accurate timestamp. This is an optional capability
> and RTEMS assumes 0 nanoseconds when this is not
> available and you end up with the pre-4.8 time is only
> accurate to a clock tick behavior.
> Thanks a lot I understood this part.
> + When this change was made, the internal time structure
> was changed to struct timespec. This is nanosecond accurate
> but terribly inefficient to do math with. Some RTEMS applications
> run on space based hardware which is VERY VERY slow to
> survive radiation. At 10-15 Mhz (YEP!) some time operations
> went up by ~20-30 microseconds. Since we use this to timestamp
> context switches, this is just flat horrible.
> + On 32-bit CPUs, Sixty-four bit math is heavier than 32-bit math
> but it is WAY better than struct timespec math.
> Sorry I did not understand this part. How can you do Sixty-four bit math
> on a 32-bit CPUs. Please guide me.
Simple. Just decompose the 64-bit word into two, 32-bit words...
-- dc
