Google SOC project tinyRTEMS
Sat Mar 22 14:24:23 UTC 2008
Ray wrote:
> Hi, YanMiao, Joel Sherrill
> I can offer some help in this ‘tiny’ project if any students interested in this.
> I believe Joel also implied that we also need add some configure options that a user can choose from when he|she want to enable the file system extra. If we accomplish the 3 topic Joel gave, RTEMS can be as small as uC-OSII in a 32-bit system.
> BTW, there might something else to do e.g. 8bit or 16bit Object-ID. In a word, we want the RTEMS a more configure-able system.
> We can break the work done and make some schedule for this.
> Just keep in mind, the application will be frozen in Mar.24, hurry up!
I think that is when the student applications can BEGIN to be filed.
Double check me though.
I think 30 March is the deadline.
I want to review student projects.
My understanding is also that we need to have assigned a mentor to each
project proposal.
Also check me on that.
Students.. please have things ready so we can help you.
> Thanks & Best Regards!
> Ray, rayx.cn at gmail.com
> 2008-03-22
> ----- Receiving the following content -----
> From:  Joel Sherrill
> Receiver:  阎淼
> Time: 2008-03-21, 21:17:43
> Subject: Re: Google SOC project tinyRTEMS
>> 阎淼 wrote:
>>> Hello all,
>>>    I  am  interest  in tinyRTEMS project,  I have read the wiki page,
>>> and there are a lot of work has been done. I would like to know what
>>> is the direction of Tiny RTEMS project.
>> As stated, its goal is to shrink the minimum footprint of an RTEMS
>> executable
>> and a number of issues have already been addressed. Many of the issues are
>> fairly subtle and if you are new to RTEMS might be hard to figure out.
>> One of the larger issues left and probably the only one worth even thinking
>> about as a GSOC project are the last three on the list.
>> *disable newlib reentrancy (which might already be partially there)
>> *disable filesystem
>> *"device table filesystem". Functionality similar to how device names were
>> handled in RTEMS 4.0.0. Now we have a real POSIX style filesystem with
>> devices. Then we had a lookup table which mapped device names into
>> major/minor. So when you call open(), the device name isn't looked up
>> in a filesystem, it is looked up in a table of strings.
>> Many of the TinyRTEMS ideas require the addition of application time
>> configuration to select the run-time capabilities. This one is a bit harder
>> because it spans the IO and filesystem infrastructure. You will have to
>> baseline
>> the size of the minimum, hello and ticker executables and work to eliminate
>> filesystem code you are replacing with a lighter alternative.
>> In minimum, you want to push to have NO filesystem and IO code.
>> In hello, you want the "device name lookup".
>> Together the list above looks to be about 1/3-1/2 of the code in the minimum
>> executable on the ARM/Thumb rtl22xx_t BSP I use as a reference. So even
>> though
>> you might only save 8-12K total, you are moving from ~24K to 12-16K minimum.
>> Does that make sense?
>> NOTE: Many space based systems using RTEMS do not use the filesystem and
>> hack it out anyway. This is just providing this reduced functionality
>> mode as
>> a real configure option.
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>   Support Available             (256) 722-9985
