Eclipse GSOC Projects
Daron Chabot
daron.chabot at usask.ca
Mon Mar 24 18:18:31 UTC 2008
Alan Cudmore wrote:
> Here is my take on the Eclipse integration and configuration GUI
> projects:
I've been using Eclipse for both Java and C/C++ applications for about a
year and a half and I think it's a very useful tool ( I can feel Eric
"real men use vi" Norum rolling his eyes at me from here... :-) ). On
the side, I also like to dabble in building Eclipse RCP (rich client
platform) projects. The Eclipse IDE is itself just a very sophisticated
RCP application.
Lately, I have also been thinking about creating some Eclipse support
for RTEMS projects.
> Eclipse Integration can include a lot of sub-projects. Some require
> no real work, just using existing tools and plug-ins. Others require
> a development effort and a pretty good knowledge of developing plug-
> ins. Some of the sub-projects include:
> 1. Basic cross development integration. This can be accomplished
> using Eclipse and the CDT ( C/C++ development toolkit ). There are at
> least a few on this list who have accomplished that. The possible
> work here is just documenting the process of setting it up, and
> deciding how the RTEMS applications will be built: Do you want to use
> the makefiles from the examples ( RTEMS_MAKEFILE_PATH ) or go with
> Chris Johns autoconf/automake based examples?
I know that the *.leaf make-system is unpopular with at least Ralf, but
what are the alternatives? I was somewhat surprised that the RTEMS
application build-system didn't make the list of GSOC projects... maybe
next year ?
At any rate, once the developer provides a Makefile, an Eclipse
C-project must be told as to where to find the cross-compiler, RTEMS
headers and libraries. To make this process more painless, an
Eclipse-RTEMS plugin could be constructed. For those who didn't know,
plugins are bundles of code that contribute new functionality to the
Eclipse IDE.
One requirement an RTEMS plugin would contribute is an RTEMS "nature" to
a C/C++ project: this "nature" would inform Eclipse where to find RTEMS
headers and libs, a cross-build toolchain, etc.
Accompanying the RTEMS "nature" could be a set of one or more
"preference pages" where a developer would configure fairly static items
such as RTEMS install and source locations, PATH additions, etc.
Finally, an RTEMS new-project "wizard" could be built. Among other
duties, this wizard would prompt the user to select from a choice of
available BSPs, modify or accept default application configuration
parameters such as which RTEMS Managers and filesystems to include,
RTEMS_TICKS_PER_MICROSECOND, etc. This sort of implies that a userConf.h
template be created (which may be useful elsewhere)...
The new-project wizard would require the most work, but may well be
worth it: How nice would it be for new users to click a few buttons and
POOF, an RTEMS "Hello World" application is instantiated from templates
and ready to be loaded onto hardware or simulator ???
> 2. GNU debugger integration. This can be accomplished using the Zylin
> Embedded CDT plugin:
> http://www.zylin.com/embeddedcdt.html
> I'm not sure if there are any other RTEMS specific things that could
> enhance the debugger interface in Eclipse. Perhaps when using CEXP
> and the RTEMS GDB stub, you can build a module and click a button to
> download it to the target?
I didn't try very hard, but I could not get Till's GDB stub + Cexp to
work within Eclipse. Regular serial and networking gdb-sessions work
quite nicely, however.
> 3. Terminal program: There are Eclipse plug-ins that provide serial
> terminal emulation. This would provide an integrated terminal program
> ( or even telnet if you want to use a target shell over the network ).
Yes. The Eclipse Remote Systems Explorer (RSE) plugin provides
integrated telnet and ftp interfaces.
> 5. Configuration GUI. If we are talking about a complete Eclipse
> integration, then I think it makes sense to build an eclipse plugin
> for an RTEMS configuration editor and perhaps a new project wizard.
> At GSFC, we developed similar eclipse plug-ins for our higher level
> application software configuration, so we ( not me personally ) have
> some experience in developing these. Our plug-in used XML to store
> the configuration parameters, and then could generate the C header
> file for compilation.
see above comments.
> Of course if the goal is not Eclipse integration, then any other
> cross platform GUI might work:
> GTK+, QT, wx, or even Java
It would be great if such a GUI-based configuration tool used
components/technology that could be leveraged from Eclipse (i.e. XML).
> Once some or all of these things are done, then how is it
> distributed? Can we package up a custom RTEMS eclipse, or just
> provide an easy way to take an eclipse release and install the
> necessary plug-ins? In other words, how can it be made a nice easy
> out of the box experience?
Distribution/packaging may be the "easy" part of any Eclipse-RTEMS
tooling: It's a simple matter to create an "update site" where Eclipse
users can point their IDE at to obtain plugins (e.g.
http://www.rtems.com/updates).
I am willing to help get this going.
-- dc
