rtems_bsdnet_show_inet_routes
Ian Caddy
ianc at goanna.iinet.net.au
Wed Mar 26 06:31:46 UTC 2008
Hi Joel,
I am not a texi person and I haven't got 4.8 setup in my system (so not
tested), but hopefully this is a patch file for the testing.t file of
the network supplement.
Let me know if it works and/or if you need me to do anymore on this.
regards,
Ian Caddy
Joel Sherrill wrote:
> Ian.. can you submit a patch that adds this explanation
> somewhere in the networking guide?
> Thanks.
> --joel
> Ian Caddy wrote:
>> Hi Leon,
>> I have had to explain almost the same things previously to our
>> customers, so I have researched this in the past.
>> Leon Pollak wrote:
>>> I have the board with two interfaces. When I run
>>> with both interfaces configured with static IP addresses I receive the
>>> following:
>>> Destination Gateway/Mask/Hw Flags Refs Use Expire
>>> Interface
>>> 127.0.0.1 127.0.0.1 UH 0 0 0 lo0
>>> 192.168.1.0 255.255.255.0 U 0 0 2 eth1
>>> 192.168.50.0 255.255.255.0 U 0 0 1 eth0
>>> But, when I define the first IF "eth0" to use bootp protocol, the
>>> result looks
>>> as following:
>>> Interface
>>> default 192.168.50.1 UGS 0 0 0 eth0
>>> 192.168.50.0 255.255.255.0 U 0 0 4 eth0
>>> 192.168.50.1 UHL 1 0 4 eth0
>>> The questions are:
>>> 1. What do the last 2 lines mean?
>> The first of the two last lines is for the default route for the subnet
>> of eth0, the same as the last line in the first section.
>> The last line is for the the connection you have had with that
>> particular IP address (your DHCP server).
>> This table is your current routing table.
>>> 2. What is the "Expire" column meaning?
>> The expire column indicates that the particular route will be dropped if
>> there is no activity for the expiry time.
>>> 3. How are the "Flags" column letters interpreted?
>> Since the stack comes from BSD, I have a link that explains a lot of
>> what I am telling you as well:
>> http://www.freebsd.org/doc/en_US.ISO8859-1/books/handbook/network-routing.html
>> Here is the list of flags:
>> U Up: The route is active.
>> H Host: The route destination is a single host.
>> G Gateway: Send anything for this destination on to this remote
>> system, which will figure out from there where to send it.
>> S Static: This route was configured manually, not automatically
>> generated by the system.
>> C Clone: Generates a new route based upon this route for machines
>> we connect to. This type of route is normally used for local
>> networks.
>> W WasCloned: Indicated a route that was auto-configured based upon
>> a local area network (Clone) route.
>> L Link: Route involves references to Ethernet hardware.
>> Hope this helps.
>> regards,
>> Ian Caddy
>> Ian Caddy
>> Goanna Technologies Pty Ltd
>> +61 8 9444 2634
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
Ian Caddy
+61 8 9444 2634
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20080326/d2c57154/attachment-0001.txt>
