(cvs head) RTEMS makefiles broken
Till Straumann strauman at slac.stanford.edu
Wed Mar 26 20:47:38 UTC 2008
Joel Sherrill wrote:
> Till Straumann wrote:
>> The (legacy) RTEMS makefile system seems to be broken on the cvs head.
>>  - doesnt' work with multilibbed cpukit
> Give me a configure command and I will try it.
I'm not saying that RTEMS and the samples don't build but external
applications which use the RTEMS Makefiles (no autotools) won't find
cpukit includes nor libraries:
a) configure RTEMS:
   ../configure --enable-multilib --enable-rtemsbsp=psim
--prefix=/opt/rtems/test --target=powerpc-rtems
b) build
c)  cp testsuites/samples/hello.c  ./
    cp testsuites/samples/system.h ./
    cp /opt/rtems/test/make/Templates/Makefile.leaf ./Makefile
d) edit makefile template
e) setenv RTEMS_MAKEFILE_PATH /opt/rtems/test/powerpc-rtems/psim
e) make
   tcsh> powerpc-rtems-gcc --pipe
-B/opt/rtems/test/powerpc-rtems/psim/lib/ -specs bsp_specs -qrtems   -g
-Wall  -O2 -g -fno-keep-inline-functions -g     -mcpu=603e
-Dppc603e      -c   -o o-optimize/init.o init.c
In file included from init.c:24:
system.h:16:19: error: rtems.h: No such file or directory
==> <rtems.h> not found because multilibbed cpukit headers live in
/opt/rtems/test/powerpc-rtems/include
f) make XCFLAGS=-B/opt/rtems/test/powerpc-rtems
 make RTEMS_MAKEFILE_PATH=/opt/rtems/test/powerpc-rtems/psim -f
Makefile.leaf XCFLAGS=-B/opt/rtems/test/powerpc-rtems powerpc-rtems-gcc
--pipe -B/opt/rtems/test/powerpc-rtems/psim/lib/ -specs bsp_specs
-qrtems   -g -Wall -B/opt/rtems/test/powerpc-rtems -O2 -g
-fno-keep-inline-functions -g     -mcpu=603e  -Dppc603e      -c   -o
make: *** No rule to make target
`/opt/rtems/test/powerpc-rtems/psim/lib/librtemscpu.a', needed by
`o-optimize/init.exe'.  Stop.
==> bad dependency in Makefile.leaf: LINK_FILES variable lists
$(PROJECT_RELEASE)/lib/librtemscpu$(LIBSUFFIX_VA)
    which expands to /opt/rtems/test/powerpc-rtems/psim/lib/librtemscpu.a
g) remove dependency on $(LINK_FILES) from Makefile.leaf (hack to be
able to proceed)
   test -d o-optimize || mkdir o-optimize
powerpc-rtems-gcc --pipe -B/opt/rtems/test/powerpc-rtems/psim/lib/
-specs bsp_specs -qrtems   -g -Wall -B/opt/rtems/test/powerpc-rtems -O2
-g -fno-keep-inline-functions -g     -mcpu=603e  -Dppc603e      -c   -o
-Wl,-Map,map  -mcpu=603e  -Dppc603e  -o o-optimize/init.exe
o-optimize/init.o
/opt/rtems/test/powerpc-rtems/psim/lib/no-barrier.rel
/opt/rtems/test/powerpc-rtems/psim/lib/no-dpmem.rel
/opt/rtems/test/powerpc-rtems/psim/lib/no-event.rel
/opt/rtems/test/powerpc-rtems/psim/lib/no-io.rel
/opt/rtems/test/powerpc-rtems/psim/lib/no-msg.rel
/opt/rtems/test/powerpc-rtems/psim/lib/no-mp.rel
/opt/rtems/test/powerpc-rtems/psim/lib/no-part.rel
/opt/rtems/test/powerpc-rtems/psim/lib/no-region.rel
/opt/rtems/test/powerpc-rtems/psim/lib/no-sem.rel
/opt/rtems/test/powerpc-rtems/psim/lib/no-signal.rel
/opt/rtems/test/powerpc-rtems/psim/lib/no-timer.rel
/opt/rtems/test/powerpc-rtems/psim/lib/no-rtmon.rel
/opt/rtems/test/powerpc-rtems/psim/lib/no-ext.rel
/opt/rtems-head/host/i386_linux26/bin/../lib/gcc/powerpc-rtems/4.2.2/../../../../powerpc-rtems/bin/ld:
cannot find -lrtemscpu
collect2: ld returned 1 exit status
make: *** [o-optimize/init.exe] Error 1
==> librtemscpu.a not found because multilibbed cpukit libraries live in
/opt/rtems/test/powerpc-rtems/lib
 h) make XCFLAGS='-B/opt/rtems/test/powerpc-rtems
-B/opt/rtems/test/powerpc-rtems/lib
==> Finally works. NOTE: library path MUST be given with -B -- otherwise
the multilib subdir
    is not appended by gcc and you'd always get the default variant!
>>  - new definitions of 'make-exe' & friends in 'leaf.cfg' cannot be
>>    overridden by make/custom/<bsp>.cfg because Makefile.inc
>>    includes 'leaf.cfg' after $(RTEMS_CUSTOM)
> Every example use of those Makefiles in CVS works with
> every BSP.  Cases which did not build for every BSP before
> this work was done now build and link.
>>  - same applies for the DOWNEXT - all BSPs end up with '.ralf'
> Yes that was the point.  We have wanted to move more to
> autoconf/automake rules and this was a step.  There is
> now a distinction between the linked program file
> produced by the linking gcc step (.exe) and the program
> you download to the target (.ralf).
That is fine -- but I thought bsps should be able
to override default commands e.g., for make-exe
or 'bsp-post-link' (or even DOWNEXT e.g., in case
some exotic firmware bootloader expects a special extension)
Because 'leaf.cfg' is included after a BSP's custom/<bsp>.cfg
file the definitions in 'leaf.cfg' always take precedence.
Take e.g., the mvme2100 BSP. It's mvme2100.cfg defines
a bsp-post-link  command (objcopy -O binary ...) but
if I build the above example (using the same hacks) I get
powerpc-rtems-gcc --pipe -B/opt/rtems/test/powerpc-rtems/mvme2100/lib/
-B/opt/rtems/test/powerpc-rtems/lib -O2 -g -mmultiple -mstring
-mstrict-align -g     -mcpu=603e -Dmpc603e -Dppc603e      -Wl,-Map,map
-mcpu=603e -Dmpc603e -Dppc603e   -o o-optimize/init.exe
o-optimize/init.o
/opt/rtems/test/powerpc-rtems/mvme2100/lib/no-barrier.rel
/opt/rtems/test/powerpc-rtems/mvme2100/lib/no-dpmem.rel
/opt/rtems/test/powerpc-rtems/mvme2100/lib/no-event.rel
/opt/rtems/test/powerpc-rtems/mvme2100/lib/no-io.rel
/opt/rtems/test/powerpc-rtems/mvme2100/lib/no-msg.rel
/opt/rtems/test/powerpc-rtems/mvme2100/lib/no-mp.rel
/opt/rtems/test/powerpc-rtems/mvme2100/lib/no-part.rel
/opt/rtems/test/powerpc-rtems/mvme2100/lib/no-region.rel
/opt/rtems/test/powerpc-rtems/mvme2100/lib/no-sem.rel
/opt/rtems/test/powerpc-rtems/mvme2100/lib/no-signal.rel
/opt/rtems/test/powerpc-rtems/mvme2100/lib/no-timer.rel
/opt/rtems/test/powerpc-rtems/mvme2100/lib/no-rtmon.rel
/opt/rtems/test/powerpc-rtems/mvme2100/lib/no-ext.rel
powerpc-rtems-nm -g -n o-optimize/init.exe > o-optimize/init.num
powerpc-rtems-size o-optimize/init.exe
   text    data     bss     dec     hex filename
 153389    7172   46517  207078   328e6 o-optimize/init.exe
cp o-optimize/init.exe o-optimize/init.ralf
I.e., the objcopy command has been overridden by 'cp'.
IMO, the
define xxx
endef
in leaf.cfg should be
ifndef xxx
define xxx
endef
endif
(likewise for DOWNEXT)
===> I maintain my claim that the makefiles are currently broken
-- T.
> Every BSP now uses the same
> .ralf - RTEMS Application Loadable File.  It was our
> nod to acknowledge Ralf.
> You download .ralf's to the target and use .exe's with
> gdb to get the symbols.
> By making the linking rules common across all BSPs, this
> opens the door for letting autoconf/make deal with it
> easier.
>> The last two problems could be fixed with the 'override' directive
>> but I don't think that's a desirable solution.
> That shouldn't be needed.  You need to download .ralf's.
> --joel
>> -- Till
