erc32 wrong compilation flags for initial task with fpu?
Aleix Conchillo Flaqué
aconchillo at ieec.cat
Thu Mar 27 17:13:42 UTC 2008
Hi,
I understand what you say and already read your posts. The problem is
that the -msoft-float is now set by default in the ERC32 bsp so it
affects RTEMS itself. May be I am missing something but checking
_Thread_Handler I see:
#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
#if ( CPU_USE_DEFERRED_FP_SWITCH == TRUE )
if ( (executing->fp_context != NULL) && !_Thread_Is_allocated_fp(
executing ) ) {
if ( _Thread_Allocated_fp != NULL )
_Context_Save_fp( &_Thread_Allocated_fp->fp_context );
_Thread_Allocated_fp = executing;
#endif
#endif
Which will never execute as the -msoft-float flag is set by default.
#if ( SPARC_HAS_FPU == 1 )
#define CPU_HARDWARE_FP TRUE
#else
#define CPU_HARDWARE_FP FALSE
#endif
and
#if defined(_SOFT_FLOAT)
#define SPARC_HAS_FPU 0
#else
#define SPARC_HAS_FPU 1
#endif
_SOFT_FLOAT is defined by -msoft-float.+
Aleix
On Thu, Mar 27, 2008 at 5:48 PM, Jiri Gaisler <jiri at gaisler.com> wrote:
> We have been through this many times, please see my earlier posts
> on this matter. In principle, the kernel should always be compiled
> with -msoft-float to avoid gcc from using float registers for
> integer operations (yes, it can do that). The application can
> be compiled with our without -msoft-float depending on if an
> FPU exists in the system. To enable FPU support, the RTEMS_FLOATING_POINT
> attribute should be set on FPU tasks if -msoft-float
> has NOT been use on the application. If -msoft-float has been used,
> the RTEMS_FLOATING_POINT should never be set.
> An interesting failure case is when gcc schedules an FPU instruction
> in a part of your application which is executed by an integer-only task
> (i.e. no RTEMS_FLOATING_POINT attribute). The task will then crash with
> an FPU disable trap, potentially killing your satellite ...
> The only way around this is to either set RTEMS_FLOATING_POINT on all
> tasks, or none.
> Jiri.
