What is "no" application? nm?
Ralf Corsepius
ralf.corsepius at rtems.org
Mon Mar 31 16:54:50 UTC 2008
On Mon, 2008-03-31 at 19:41 +0300, Leon Pollak wrote:
> On Monday, 31 בMarch 2008, Ralf Corsepius wrote:
> > Do other (opensource) BSPs build for you?
> I tried mpc8260ads:
> With the 'powerpc-rtems-4.9-nm' link for 'no' - yes, everything compiles and
> links fine.
> Without this link, all EXE generation fails.
> Ooops... Just now I noticed that I use the so called 4.9 tool chain. Is this
> incorrect and may be harmful?
Difficult to answer.
* rtems4.9 and the rtems4.8 toolchains' binutils are more or less
identical
* rtems4.9-gcc is at gcc-4.3.0, while rtems4.8-gcc is at gcc-4.2.x.
* rtems4.9-newlib is newlib-1.16.0, rtems4.8-newlib is newlib-1.15.0.
Basically, both toolchains should be widely compatible, but there are
known substantial differences in details.
Ralf
