contrib: DHCP network monitor and fallback from DHCP to static address
Thu May 1 13:03:19 UTC 2008
Chris Johns wrote:
> Arnout Vandecappelle wrote:
>>>>  Hoi,
>>>>  My colleague Maarten and I have developed an extension to the DHCP
>>>> client which allows monitoring the network interface and restarting DHCP
>>>> when the network changes.
>> [snip]
>>> Why was the nfs_diskless_valid code removed ?
>>  Because it is useless as it is (nfs_diskless_valid is never set in the
>> existing code, and is not exported in any header; it's historical in the
>> bsdnet code and has been copied blindly into the DHCP client code).  In
>> addition, if anyone would ever set nfs_diskless_valid to one, the
>> do_dhcp_timeout wouldn't work anymore...
> Ok.
>>> The rtems_bsdnet_do_dhcp change is wrong. You need to obtain the
>>> network semaphore after the timeout not release it.
>>  Ouch.  Good observation.
>>> Why the changes in bootp_subr.c with the order of the calls to ifioctl ?
>>  Oops.  Fall-out from trying to re-configure the interface without
>> de-configuring it first.  Slipped through my minimal-change filter.
>> Shouldn't make any difference, though.
>>  The last two issues are removed in the attached patch.  However, this
>> has not been tested at all because I don't have access to the board
>> anymore...
> This look fine and I have committed changes. I have removed the dhcp_task_id
> initialisation as an uninitialised value is set to 0 and this save ROM space.
> In the fail safe code and I see do_dhcp_init is global. Should this be static
> ? I have made it static.
> I have had to fix the includes to get the fail safe code to compile. Please
> check the code in CVS.
> I have tested the normal DHCP operation on the mcf5235 BSP.
> Thanks for the patch.
Thanks for reviewing and committing it.  Can you write
up an entry for the 4.9 release notes and add it to...
http://www.rtems.org/wiki/index.php/4.9_Release_Notes
> Regards
> Chris
> rtems-users mailing list
> rtems-users at rtems.com
