Using RTEMS kernel on arm based board - bare bsp
Vinod Kulkarni
vinodk at tataelxsi.co.in
Mon May 5 08:59:22 UTC 2008
Hi,
My serial port settings are:
Baud - 115200
Data - 8
Stop - 1
Parity - None
Hardware flow control - None
Software flow control - None
Could you please tell me what is the expected behavior (I have loaded
hello.exe file)?
Regards
Vinod
_____
Sent: Monday, May 05, 2008 2:09 PM
To: vinodk at tataelxsi.co.in
Cc: rtems-users at rtems.com
Subject: Re: Using RTEMS kernel on arm based board - bare bsp
It is not the expected behavior.
How about your serial port's setting, Rate/Nor/7bit.....
2008/5/5 Vinod Kulkarni <vinodk at tataelxsi.co.in>:
Hi,
I am using arm based board (PXA255 based). I have built RTEMS kernel
with bare bsp. I have my own boot-loader which is capable of loading the
kernel. Once I load the kernel I am getting a dot (.) as the output. Could
you please let me know whether this is the expected behavior?
Regards
Vinod
The information contained in this electronic message and any attachments to
this message are intended for the exclusive use of the addressee(s) and may
contain proprietary, confidential or privileged information. If you are not
the intended recipient, you should not disseminate, distribute or copy this
e-mail. Please notify the sender immediately and destroy all copies of this
message and any attachments contained in it. Contact your Administrator for
further information.
rtems-users mailing list
http://rtems.rtems.org/mailman/listinfo/rtems-users
Thanks & Best Regards!
Ray, Xu
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain proprietary, confidential or privileged information. If you are not the intended recipient, you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately and destroy all copies of this message and any attachments contained in it.
Contact your Administrator for further information.
URL: <http://lists.rtems.org/pipermail/users/attachments/20080505/57f892e4/attachment.html>
