RTEMS stack + TSIM-LEON2 weird behaviour
Aitor Viana
aitor.viana.sanchez at esa.int
Tue May 6 09:50:34 UTC 2008
Actually it is not completely off-topic, I tell you why...
If I disassemble the executable and go to the hard_reset function:
40001000 <hard_reset>:
40001000: 03 10 00 00 sethi %hi(0x40000000), %g1
40001004: 82 10 60 00 mov %g1, %g1 ! 40000000 <RAM_START>
40001008: 81 98 40 00 mov %g1, %tbr
4000100c: 83 48 00 00 rd %psr, %g1
40001010: 84 00 60 01 add %g1, 1, %g2
40001014: 84 08 a0 07 and %g2, 7, %g2
40001018: 86 10 20 01 mov 1, %g3
4000101c: 87 28 c0 02 sll %g3, %g2, %g3
40001020: 81 90 c0 00 mov %g3, %wim
40001024: 82 10 60 20 or %g1, 0x20, %g1
40001028: 81 88 40 00 mov %g1, %psr
4000102c: 01 00 00 00 nop
40001030: 01 00 00 00 nop
40001034: 01 00 00 00 nop
40001038: 0d 10 00 01 sethi %hi(0x40000400), %g6
4000103c: 8c 11 a3 c0 or %g6, 0x3c0, %g6 ! 400007c0
<_ERC32_MEC_Timer_Control_Mirror>
*40001040: dc 21 80 00 st %sp, [ %g6 ]*
40001044: 23 10 00 4a sethi %hi(0x40012800), %l1
40001048: a2 14 61 64 or %l1, 0x164, %l1 ! 40012964
<Configuration>
4000104c: e6 04 60 04 ld [ %l1 + 4 ], %l3
*40001050: 9c 23 80 13 sub %sp, %l3, %sp
40001054: 9c 2b a0 0f andn %sp, 0xf, %sp
40001058: bc 10 00 0e mov %sp, %fp
*4000105c: 01 00 00 00 nop
40001060: 05 10 00 4a sethi %hi(0x40012800), %g2
40001064: 84 10 a0 a0 or %g2, 0xa0, %g2 ! 400128a0
<_endtext>
40001068: 07 10 00 4a sethi %hi(0x40012800), %g3
4000106c: 86 10 e0 a0 or %g3, 0xa0, %g3 ! 400128a0
<_endtext>
40001070: 09 10 00 4d sethi %hi(0x40013400), %g4
40001074: 88 11 22 70 or %g4, 0x270, %g4 ! 40013670
<__bss_start>
40001078: 80 a0 80 03 cmp %g2, %g3
4000107c: 02 80 00 09 be 400010a0 <copy_data+0x1c>
40001080: 01 00 00 00 nop
Find in bold where the %sp is modified. There is not single instruction to
set up the %sp register. The first one stores the VALUE of the %sp into the
address pointed by %g6, and the next operation over the %sp subtract fro
%sp, so the %sp value should be 0xFFFFXXXX ??? and this is RTEMS business.
Again the question is where the %sp is set, in RTEMS ?
the ./lib/libbsp/sparc/shared/start.S file matches with the disassemble
code...
On Tue, May 6, 2008 at 11:41 AM, Ralf Corsepius <ralf.corsepius at rtems.org>
wrote:
> On Tue, 2008-05-06 at 10:16 +0200, Aitor.Viana.Sanchez at esa.int wrote:
> > Hi all,
> > I've got some weird (for me) when executing the rtems-hello example in
> > the tsim-leon2 professional version.
> Off topic for this list - Ask Gaisler.
> Ralf
URL: <http://lists.rtems.org/pipermail/users/attachments/20080506/b2b2dd82/attachment.html>
