H8SX porting effort stumped
Steven Grunza
grunza at ulticom.com
Wed May 7 17:14:02 UTC 2008
Hello,
I'm working on porting RTEMS to the Renesas H8SX and I've hit a bug I
can't figure out.
Background:
The RTEMS data structure _Configuration of type
rtems_configuration_table is created in the
examples-4.7.99.2/hello_world_c/test.c file by including
<rtems/confdefs.h>
After passing the --save-temps directive into the build I can see the
following in test.s:
.global _Configuration
.align 2
.type _Configuration, @object
.size _Configuration, 56
_Configuration:
.long 16719872
.long 17624
.long 0
.long 10000
.long 50
.long 1
.long 1
.long _Device_drivers
.long 1
.long _Configuration_Initial_Extensions
.long 0
.long _Configuration_RTEMS_API
.long 0
.long 0
In hello.num I can see the following addresses:
00015430 T _rodata_start
00480000 D _data_start
004800a0 D _Configuration
So it appears that the _Configuration is stored in SRAM (which starts
at 0x0048_0000) at 0x0048_00a0. Given the simple block copy done to get
the initialized data from the read only area to the initialized area my
guess is that the initialization data for the _Configuration structure
should be at
0x0001_54d0 which is 0xa0 bytes into the read only data area
I took the S-record format of the hello.exe ELF executable and used
objcopy to make a binary image of it. I then used hexedit to look at
the binary image. Since my executable begins with a vector table at
0x0000_0000 there shouldn't be any offsets to worry about.
Thanks for reading this far...
Here's the issue:
At 0x0001_54d0 there's ASCII data, not the data necessary to setup the
_Configuration structure. My guess is that since the first long word
appears to be intended to be an address, bad things are happening in my
code because the _Configuration structure is really hosed...
00015430 0A 0A 2A 2A 2A 20 48 45 4C 4C 4F 20 57 4F 52 4C ..***
HELLO WORL
00015440 44 20 54 45 53 54 20 2A 2A 2A 00 48 65 6C 6C 6F D TEST
***.Hello
00015450 20 57 6F 72 6C 64 00 2A 2A 2A 20 45 4E 44 20 4F
World.*** END O
00015460 46 20 48 45 4C 4C 4F 20 57 4F 52 4C 44 20 54 45 F HELLO
WORLD TE
00015470 53 54 20 2A 2A 2A 00 00 00 00 00 00 00 00 00 00 ST
00015480 00 00 07 82 00 00 06 B6 00 00 00 00 00 00 00 00
00015490 00 00 00 00 00 00 00 00 6D 69 6E 6F 72 20 3C 3D
........minor <=
000154A0 20 31 00 2E 2E 2F 2E 2E 2F 2E 2E 2F 2E 2E 2F 2E
1.../../../../.
000154B0 2E 2F 2E 2E 2F 2E 2E 2F 2E 2E 2F 72 74 65 6D 73
./../../../rtems
000154C0 2F 63 2F 73 72 63 2F 6C 69 62 2F 6C 69 62 62 73
/c/src/lib/libbs
000154D0 70 2F 68 38 33 30 30 2F 68 38 73 78 5F 72 73 6B
p/h8300/h8sx_rsk
000154E0 2F 2E 2E 2F 2E 2E 2F 73 68 61 72 65 64 2F 63 6F
/../../shared/co
000154F0 6E 73 6F 6C 65 2D 70 6F 6C 6C 65 64 2E 63 00 2F
nsole-polled.c./
00015500 64 65 76 2F 63 6F 6E 73 6F 6C 65 00 52 54 45 4D
dev/console.RTEM
00015510 53 00 61 73 73 65 72 74 69 6F 6E 20 22 25 73 22
S.assertion "%s"
00015520 20 66 61 69 6C 65 64 3A 20 66 69 6C 65 20 22 25 failed:
file "%
00015530 73 22 2C 20 6C 69 6E 65 20 25 64 0A 00 2E 2E 00 s", line
%d.....
00015540 4D 61 6C 6C 6F 63 20 73 74 61 74 73 00 20 20 61 Malloc
stats. a
00015550 76 61 69 6C 3A 25 6C 75 6B 20 20 61 6C 6C 6F 63 vail:%luk
alloc
00015560 61 74 65 64 3A 25 6C 75 6B 20 28 25 6C 64 25 25 ated:%luk
(%ld%%
00015570 29 20 6D 61 78 3A 25 6C 75 6B 20 28 25 6C 75 25 )
max:%luk (%lu%
00015580 25 29 20 6C 69 66 65 74 69 6D 65 3A 25 6C 6C 75 %)
lifetime:%llu
00015590 6B 20 66 72 65 65 64 3A 25 6C 6C 75 6B 0A 00 20 k
freed:%lluk..
This message is already long but if anyone is interested in helping I
can send whatever files would be useful, such as the linker command
script.
"Unix is user friendly, it's just Steven Grunza
particular about with whom it voice: (856) 787 - 2759
makes friends." fax: (856) 866 - 2033
- Unknown mailto:grunza at ulticom.com
flames:/dev/null
