GSOC:disable newlibc reentrancy
阎淼 yanmiaobest at gmail.com
Thu May 8 12:35:56 UTC 2008
2008/5/8, Ralf Corsepius <ralf.corsepius at rtems.org>:
> > > On Thu, 2008-05-08 at 14:54 +0800, 阎淼 wrote:
> > > > Hi,
> > > > I am trying to disable newlibc.c reentrant support.
> > > Why do you want to do this?
> > That is one of the size reduction ideas of tiny rtems project.
> OK, in verbose: What you are doing is absurd. It means to cut-off rtems
> from newlib, turning all of newlib and the whole compiler unusable.
   What is your suggestion?  And if newlibc reentrant extensions are
not supposed to be an option,  why macro like
CONFIGURE_DISABLE_NEWLIB_REENTRANCY exists in confdefs.h ?
> Ralf
