How to start a timer as a result of interrupt processing
Thu May 8 14:33:50 UTC 2008
Ingolf Steinbach wrote:
> 2008/5/8 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>  It is OK to call rtems_timer_fire_after() or rtems_timer_cancel()
>>  from an ISR.
> Thanks, Joel, for the clarification. Does this apply to HEAD only or
> also to 4.8/4.7?
>> Just an oversight in the documentation.
> Should I open a bugzilla entry?
You can and it would be even better if it had a patch for
the manual.  <hint> <hint> it is in doc/user. :-D
> Kind regards
> Ingolf
