release and debug mode heap allocation
Aleix Conchillo Flaqué aconchillo at ieec.cat
Tue May 27 14:05:08 UTC 2008
On Sun, May 25, 2008 at 11:38 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Usually this is either because you haven't completely accounted
> for all task stack or message buffer memory in your application or
> there is an error in confdefs.h which results in an underestimate
> of the memory required.
> Are all your task stacks of minimum size?
According to the stack checker, none of the tasks passes the 4096
bytes. I have setup a minimum stack of 8192 without luck.
> Is the error something like "out of memory"
About my last message about the fatal extension, forget it, this does
not affect. The rtems_task_create routine returns RTEMS_UNSATISFIED
without any messages.
Aleix
