rtems_libio_init in 4.8.0
Antoine Lacroix lacroix.antoine at free.fr
Tue May 27 19:47:38 UTC 2008
Hi Joel,
to answer to your question about the executable size when switching from
4.7.1 to 4.8, no, in my case there is almost no change (<<1% in text size).
I must precise that I just use the following managers in my application: io
event timer message semaphore.
Antoine
----- Original Message -----
From: "Joel Sherrill" <joel.sherrill at oarcorp.com>
To: "Antoine Lacroix" <lacroix.antoine at free.fr>
Cc: "RTEMS Users Mailing List" <rtems-users at rtems.com>
Sent: Friday, May 23, 2008 7:10 PM
Subject: Re: rtems_libio_init in 4.8.0
> Antoine Lacroix wrote:
>> You're right Joel, I'm a bit ashamed of my mistake. Strange, it worked
>> fine
>> in 4.7.1 without the manager declaration.
> Ahh.. now I remember the subtle change.  In 4.7 and older,
> some managers were considered required.  Now no
> managers are considered required.
> confdefs.h didn't change that much between 4.7 and 4.8
> except to add new managers.  After 4.8, you have more
> options but the defaults should be the same as before.
> Out of curiosity, did your linked executable get smaller?
> Could you share with us the change?
> Thanks.
> --joel
>> Thanks a lot Joel.
>> John
>> To: "John Pickwick" <john.pickwick at free.fr>
>> Sent: Friday, May 23, 2008 4:03 PM
>>> John Pickwick wrote:
>>>> Hi to all,
>>>> I have migrated my application from rtems4.7.1/leon2 to
>>>> rtems4.8.0/leon2
>>>> and
>>>> it now fails during boot up phase. I have isolated the source of the
>>>> fatal
>>>> error call: in rtems_libio_init the first call to
>>>> rtems_semaphore_create
>>>> fails and returns with code RTEMS_TOO_MANY.
>>>> I have not changed anything in my configuration settings, does anybody
>>>> have
>>>> a clue or a hint about differences in confdefs.h requirements between
>>>> 4.7.1
>>>> and 4.8.0 ?
>>> I don't know of anything obvious in confdefs.h.
>>> Is your application build with the semaphore manager
>>> (e.g. MANAGERS = xxx)?  If you don't include the semaphore
>>> manager, this is very likely to happen.
>>>> Thanx,
>>>> John
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>   Support Available             (256) 722-9985
