how do I use shell.c?
Thu May 1 02:29:20 UTC 2008
mike wrote:
> Thanks for the reply, Ian,
> - We have an Sparc eval board that has 2 ports: 1 is debug port, 1 is
> application port.
>  From debug port, I load/run application. The output goes out to the
> rs-232 application port.
> So, am I supposed to specify this app port (/dev/console) as 'device' to
> shell_init(...)?
> When I tried that, I got the message:
> "shell: unalbel to open stdin./dev/console:Too many open files in system"?
>  -mike-
You need to increase the number of file ops in confdefs.h.
The shell is documented in the CVS RTEMS. Take a look here:
http://www.rtems.org/onlinedocs/doc-current/share/rtems/html/shell/index.html
This relates to the code in CVS. Joel and I have been hacking on the shell lately.
Regards
