No sparc-rtems4.7-gdb rpm for SuSE 10.3?
Ralf Corsepius ralf.corsepius at rtems.org
Mon May 5 10:10:19 UTC 2008
On Mon, 2008-05-05 at 12:02 +0200, Ingolf Steinbach wrote:
> 2008/5/5 Ralf Corsepius <ralf.corsepius at rtems.org>:
> >  1. sparc-rtems4.7-gdb has always been problematic (read it was bugged)
> >  to build in general and so far has always failed to build for SuSE.
> Is it just the build procedure which was/is bugged? Or is it
> sparc-rtems4.7-gdb itself which exhibits bugs at runtime?
Neither. The sparc-simulator code inside of the ancient version of gdb
sparc-rtems4.7-gdb is based on is broken and fails to build on newer
hosts (such as Fedora and SuSE).
I believe to have fixed this issue by having upgraded
sparc-rtems4.8/9-gdb to more recent versions and by hacking up the code
of sparc-rtems4.8-gdb + sparc-rtems4.9-gdb, but haven't gotten around
yet to look into rtems-4.7-gdb ... :)
Ralf
