Using RTEMS kernel on arm based board - bare bsp
xu ray rayx.cn at gmail.com
Tue May 6 08:14:59 UTC 2008
Bare BSP without any changes? Then after booting, the PXA's register for
uart should be the reset value, and You will have to check the datasheet for
its configurations. Do you change the memory map?
There is no BSP related PXA. You can refer to any ARM9 BSP. And add your
changes for PXA.
2008/5/6 Vinod Kulkarni <vinodk at tataelxsi.co.in>:
>  Hi,
>     Even the kernel compiled with bare BSP would print that?
> I have one more question. Which is the suitable BSP for PXA255 based
> board?
> Regards
> Vinod
> -----Original Message-----
> From: xu ray [mailto:rayx.cn at gmail.com <rayx.cn at gmail.com>]
> Sent: Mon 5/5/2008 4:37 PM
> To: Vinod Kulkarni
> Cc: rtems-users at rtems.com
> Subject: Re: Using RTEMS kernel on arm based board - bare bsp
> BSP by default will not out put anything.
> You serial port should get:
> *** HELLO WORLD TEST ***
> Hello World
> END OF HELLO WORLD TEST
> press any key to restart
> That is the same for all ARM ports, some BSP might output debug info when
> loading driver. However, I believe yours does not. You might need to check
> your console driver's code.
> 2008/5/5 Vinod Kulkarni <vinodk at tataelxsi.co.in>:
> >  Hi,
> >     My serial port settings are:
> > Baud - 115200
> > Data - 8
> > Stop - 1
> > Parity - None
> > Hardware flow control - None
> > Software flow control - None
> > Could you please tell me what is the expected behavior (I have loaded
> > hello.exe file)?
> > Regards
> > Vinod
> > *From:* xu ray [mailto:rayx.cn at gmail.com <rayx.cn at gmail.com>]
> > *Sent:* Monday, May 05, 2008 2:09 PM
> > *To:* vinodk at tataelxsi.co.in
> > *Cc:* rtems-users at rtems.com
> > *Subject:* Re: Using RTEMS kernel on arm based board - bare bsp
> > It is not the expected behavior.
> > How about your serial port's setting, Rate/Nor/7bit.....
> > Hi,
> >     I am using arm based board (PXA255 based). I have built RTEMS kernel
> > with bare bsp. I have my own boot-loader which is capable of loading the
> > kernel. Once I load the kernel I am getting a dot (.) as the output.
> Could
> > you please let me know whether this is the expected behavior?
> > Regards
> > Vinod
> > The information contained in this electronic message and any attachments
> > to this message are intended for the exclusive use of the addressee(s)
> and
> > may contain proprietary, confidential or privileged information. If you
> are
> > not the intended recipient, you should not disseminate, distribute or
> copy
> > this e-mail. Please notify the sender immediately and destroy all copies
> of
> > this message and any attachments contained in it. Contact your
> Administrator
> > for further information.
> > rtems-users mailing list
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
> > Thanks & Best Regards!
> > Ray, Xu
> and
> are
> copy
> of
> Administrator
> Ray, Xu
>  This message (including any attachment) is confidential and may be
> legally privileged. Access to this message by anyone other than the intended
> recipient(s) listed above is unauthorized. If you are not the intended
> recipient you are hereby notified that any disclosure, copying, or
> distribution of the message, or any action taken or omission of action by
> you in reliance upon it, is prohibited and may be unlawful. Please
> immediately notify the sender by reply e-mail and permanently delete all
> copies of the message if you have received this message in error.
Ray, Xu
URL: <http://lists.rtems.org/pipermail/users/attachments/20080506/edce35d4/attachment-0001.html>
