RTEMS stack + TSIM-LEON2 weird behaviour
    Ingolf Steinbach
    ingolf.steinbach at googlemail.com
    Tue May  6 12:12:27 UTC 2008
2008/5/6 Aitor Viana <aitor.viana.sanchez at esa.int>:
> Find in bold where the %sp is modified. There is not single instruction to
> set up the %sp register.
The RTEMS/sparc startup code assumes %sp to point slightly(*) before
the end of RAM. This is usually performed by
- the boot loader (if any) created for instance by mkprom or
- tsim/grmon.
Kind regards
Ingolf
(*) IIRC, end_of_RAM - 16 bytes
