RTEMS stack + TSIM-LEON2 weird behaviour
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Tue May  6 14:40:21 UTC 2008
Aitor.Viana.Sanchez at esa.int wrote:
> > The initial value of %sp seens to be 0 on the sparc configurations I
> have.
> > So the sub instruction you highlighted above would set the %sp to
> > the area below the work space.
> > This code hasn't changed in a LONG time and makes assumptions about
> > the execution environment which I cannot personally guarantee.  Jiri
> > would be able to do so.
> i am pretty sure (Jiri will correct me if I am wrong) that TSIM
> initializes %sp and %fp to allow direct RAM execution in case the SW
> does not have a bootstrap SW behind (e.g. mkprom)
> > My first thought this morning is that this may have been a valid
> assumption
> > at one time (initial %sp is 0) but with more variations and starting
> > environments,
> > it may not be valid anymore.  I would guess that the "sub" statement
> would
> > be better changed to a "mov %l3, %sp" and ignore the inherited %sp.
> I think this a good solution.
It is certainly simple.  We need confirmation from Jiri or Daniel.
> Regards,
> Aitor
