RTEMS stack + TSIM-LEON2 weird behaviour
Jiri Gaisler
jiri at gaisler.com
Tue May 6 16:14:32 UTC 2008
%sp is set either by the boot loader (mkprom), grmon
or rdbmon (gdb stub). The %sp is also stored to an
unused part of the trap table (0x7C0). This works
fine without any problems on both simulator and
real hardware ...
Jiri.
Joel Sherrill wrote:
> I don't disagree. But why is the stack pointer set the way it is in
> start.S? It assumes some value is in %sp from the invoking environment.
> If that
> isn't 0, it looks to me that the code doesn't work.
> --joel
>> Jiri.
>>> Aitor.Viana.Sanchez at esa.int wrote:
>>>>> The initial value of %sp seens to be 0 on the sparc configurations I
>>>> have.
>>>>> So the sub instruction you highlighted above would set the %sp to
>>>>> the area below the work space.
>>>>> This code hasn't changed in a LONG time and makes
>>>>> assumptions about
>>>>> the execution environment which I cannot personally guarantee. Jiri
>>>>> would be able to do so.
>>>> i am pretty sure (Jiri will correct me if I am wrong) that TSIM
>>>> initializes %sp and %fp to allow direct RAM execution in case the SW
>>>> does not have a bootstrap SW behind (e.g. mkprom)
>>>>> My first thought this morning is that this may have been a valid
>>>> assumption
>>>>> at one time (initial %sp is 0) but with more variations and starting
>>>>> environments,
>>>>> it may not be valid anymore. I would guess that the "sub" statement
>>>> would
>>>>> be better changed to a "mov %l3, %sp" and ignore the inherited %sp.
>>>> I think this a good solution.
>>> It is certainly simple. We need confirmation from Jiri or Daniel.
>>>> Regards,
>>>> Aitor
