GSOC:disable newlibc reentrancy
Sven.BIEBAUT at be.thalesgroup.com
Thu May 8 13:46:33 UTC 2008
> -----Original Message-----
> From: rtems-users-bounces at rtems.org
> [mailto:rtems-users-bounces at rtems.org] On Behalf Of Ralf Corsepius
> Sent: 08 May, 2008 15:40
> To: Joel Sherrill
> Cc: rtems-users at rtems.org
> Subject: Re: GSOC:disable newlibc reentrancy
> On Thu, 2008-05-08 at 08:30 -0500, Joel Sherrill wrote:
> > Ralf Corsepius wrote:
> > > On Thu, 2008-05-08 at 20:43 +0800, xu ray wrote:
> > >> libc_global_reent structure will take 1kb SRAM. This
> relic is too
> > >> big for a system with only a few k sram. Though the pointer to
> > >> libc_reent is used in thread dispatch, it is not a must
> for thread dispatch.
> > > What you are doing is abusing the RTEMS infrastructure
> for something
> > > which isn't RTEMS, nor using the RTEMS toolchain.
> > > Your are converting RTEMS into a bare metal skeleton and
> abusing the
> > > RTEMS toolchains to build a bare-metal based minimal
> scheduler library.
> > More than anything else, it is treating RTEMS as a set of
> pieces that
> > can compose a variety of systems at application configure time. No
> > special compiles, no differences in the toolset.
> Gradually I getting angry at you:
> * A define in cpukit is a special compile.
> * A define in cpukit voids all the structural work we had
> done to cpukit in recent years.
> > And from a historical perspective, RTEMS was nothing but a
> scheduler
> > until about version 3.2.
> Ten years ago.
> Then newlib had been adopted, RTEMS had been made POSIX
> compiliant ....
> now, you are reverting all this ten years of work and turning
> RTEMS into toy
> > In retrospect, we should
> > not have created the linkages between subsystems that made so many
> > things required when they really were not.
> > I do not want special tools or special builds of RTEMS
> You will have to, because the RTEMS toolchain's ABI doesn't
> match to your libc-less TinyRTEMS. It's a bare-metal target.
> For bare-metal targets nobody needs RTEMS. He needs a minial
> scheduler library.
with a lot of evidence and years of correct working history, support for
lots of different processors and a large supporting user base
And the possibility to add com ponents as your system requires it during its
20 odd years of support to the customer !
I would hardly call this a toy ...
My 2 cts.
> Ralf
> rtems-users mailing list
> rtems-users at rtems.com
