GSOC:disable newlibc reentrancy
Kenneth J. Peters
Kenneth.J.Peters at jpl.nasa.gov
Thu May 8 15:40:51 UTC 2008
Joel Sherrill wrote:
> On a bigger scale, I have been trying to get time to write
> up something on RTEMS Execution Profiles so we have
> real guidelines to judge by. I have not named/defined
> all of the profiles yet but see these two as definite and
> the high end goal when --enable-posix is specified.
> + POSIX Realtime Controller System Profile (PSE52) -
> simple file system implementation, one implicit
> process with threads support. 287 APIs according to
> one source.
> + POSIX Minimal Realtime System Profile (PSE51) -
> no filesystem, one implicit process with threads
> support. 626 APIs according to one source.
> NOTE: I have not yet found a complete list of those
> APIs to judge RTEMS by. PSE53 and PSE54
> require processes. PSE54 is full POSIX. If
> someone can find a list of API calls required,
> I would like to know so we can audit against
> the profiles.
See IEEE 1003.13–2003, “Standardized Application Environment Profile -
POSIX Realtime and Embedded Application Support (AEP)” at
http://ieeexplore.ieee.org/xpl/standardstoc.jsp?isnumber=29578
Ken Peters
