GSOC:disable newlibc reentrancy
Joel Sherrill
joel.sherrill at OARcorp.com
Thu May 8 17:10:14 UTC 2008
Ralf Corsepius wrote:
>>> Then remove this silly CONFIGURE*REENTRANCY crap you added to RTEMS.
>>> THIS makes builds using it a SPECIAL build and renders shipping binaries
>>> of cpukit IMPOSSIBLE.
>> Ralf.. it doesn't. I don't know what it is going to take to
>> make you see that configures in confdefs.h have no impact
>> on how cpukit is built.
> The OP asked to use it inside of cpukit!
Either bad English or bad implementation choice. It didn't
have to be implemented that way.
A patch adding this as a cpukit conditional compile would
have been rejected with the suggestion that it could be
a pluggable thing confdefs.h triggers.
> BTW: The origin of what you call reentrancy bloat is in newlib and
> newlib's support routines inside of RTEMS.
> As I already wrote elsewhere: You are in error to believe RTEMS will
> ever be able to compete with highly optimized bare-metal scheduling
> libraries. This is what makes this whole GSOC project a waste of time.
We disagree here. ARM/Thumb fully linked executables
can be 24k. A while back, Ray produced a ticker with
some hacks that was around 18K. Three tasks, full startup,
shutdown, etc. So we are already approaching the right
range
It isn't about beating a small low functionality scheduler
in size -- it is getting into the same ballpark so we can
run on the same hardware target. We will win users because
RTEMS is a full system with the capability to scale from that
small machine up to much larger systems. The
smaller schedulers are the toys that don't scale.
I haven't examined the minimum executable on the ARM/Thumb
in the past two months but the last time I looked, it could be
reduced significantly with no recompile of cpukit. It just needed
some way to break dependencies and eliminate code it
didn't need. No cpukit recompile -- all at link time.
> Ralf
