RTEMS stack + TSIM-LEON2 weird behaviour
Jiri Gaisler
jiri at gaisler.com
Mon May 19 08:27:02 UTC 2008
The code at line 228 in start.S stores the memory size into
address 0x7C0 in the trap table:
Assembly:
set (SYM(rdb_start)), %g6 ! End of work-space area
st %sp, [%g6]
set (SYM(Configuration)), %l1
ld [%l1+4], %l3 ! work_space_size
sub %sp, %l3, %sp ! set %sp to area below work_space
andn %sp, 0x0f, %sp ! align stack on 16-byte boundary
mov %sp, %fp ! Set frame pointer
nop
Simulator:
49 40001038 0d100001 sethi %hi(0x40000400), %g6
50 4000103c 8c11a3c0 or %g6, 0x3c0, %g6
51 40001040 dc218000 st %sp, [%g6]
60 40001044 2310005b sethi %hi(0x40016c00), %l1
61 40001048 a2146134 or %l1, 0x134, %l1
62 4000104c e6046004 ld [%l1 + 0x4], %l3
66 40001050 9c238013 sub %sp, %l3, %sp
75 40001054 9c2ba00f andn %sp, 0xf, %sp
76 40001058 bc10000e mov %sp, %fp
77 4000105c 01000000 nop
I think that the comment 'End of work-space area' is not quite correct.
The rdbmon debug stub uses the 0x7C0 info to know how much memory is
in the system.
Jiri.
Joel Sherrill wrote:
> Jiri Gaisler wrote:
>> %sp is set either by the boot loader (mkprom), grmon
>> or rdbmon (gdb stub). The %sp is also stored to an
>> unused part of the trap table (0x7C0). This works
>> fine without any problems on both simulator and
>> real hardware ...
> I understand that but what is the purpose
> of the sub instruction at line 228 of start.S?
> It is using the original %sp in math to get
> the starting stack.
> Is the value of %sp always 0 here? Or is it
> possible to be non-zero?
> If it is always zero, then a mov would be safer.
> If it is non-zero, does this statement make sense?
> I trust the environment is right when the BSP
> gets control. I have never seen a problem but
> the math just bothers me and there must be
> a guarantee I am missing.
> --joel
>> Jiri.
>>> I don't disagree. But why is the stack pointer set the way it is in
>>> start.S? It assumes some value is in %sp from the invoking environment.
>>> If that
>>> isn't 0, it looks to me that the code doesn't work.
>>> --joel
>>>> Jiri.
>>>>> Aitor.Viana.Sanchez at esa.int wrote:
>>>>>>> The initial value of %sp seens to be 0 on the sparc configurations I
>>>>>> have.
>>>>>>> So the sub instruction you highlighted above would set the %sp to
>>>>>>> the area below the work space.
>>>>>>> This code hasn't changed in a LONG time and makes
>>>>>>> assumptions about
>>>>>>> the execution environment which I cannot personally guarantee. Jiri
>>>>>>> would be able to do so.
>>>>>> i am pretty sure (Jiri will correct me if I am wrong) that TSIM
>>>>>> initializes %sp and %fp to allow direct RAM execution in case the SW
>>>>>> does not have a bootstrap SW behind (e.g. mkprom)
>>>>>>> My first thought this morning is that this may have been a valid
>>>>>> assumption
>>>>>>> at one time (initial %sp is 0) but with more variations and starting
>>>>>>> environments,
>>>>>>> it may not be valid anymore. I would guess that the "sub" statement
>>>>>> would
>>>>>>> be better changed to a "mov %l3, %sp" and ignore the inherited %sp.
>>>>>> I think this a good solution.
>>>>> It is certainly simple. We need confirmation from Jiri or Daniel.
>>>>>> Regards,
>>>>>> Aitor
