Watchdog device driver
Andrei Chichak groups at chichak.ca
Thu May 22 02:14:31 UTC 2008
At 05:12 PM 5/21/2008, you wrote:
>This is a good idea. I see the driver as something like:
>   int wd = open ("/dev/wd0", O_WRONLY, 0);
>   ioctl (wd, RTEMS_WDOG_RESET);        /* reset the watchdog */
>   ioctl (wd, RTEMS_WDOG_CONFIG, 250);  /* set the timeout to be 250msec */
>   ioctl (wd, RTEMS_WDOG_TRIGGER);      /* trigger a watchdog reset */
>   close (wd);
>Regards
I like the interface, in all of the systems that I have written there
was a two phase strobbing, I suspect that would be the RESET and TRIGGER, yes?
Where in the BSP would this sort of stuff go? (Being a moderate
newbie I have to ask. I didn't know there was support for SPI, I'll
have to look that up)
A
Andrei Chichak
Systems Developer
CBF Systems
Suite 4-038
11421 Saskatchewan Drive
Edmonton, Alberta
Canada T6G 2M9
V: (780) 628-2072
F: (780) 628-5542
