release and debug mode heap allocation
Aleix Conchillo Flaqué aconchillo at ieec.cat
Tue May 27 13:48:28 UTC 2008
On Sun, May 25, 2008 at 11:38 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Usually this is either because you haven't completely accounted
> for all task stack or message buffer memory in your application or
> there is an error in confdefs.h which results in an underestimate
> of the memory required.
> Are all your task stacks of minimum size?
Mmm, I see, I will check this. Thanks.
> Is the error something like "out of memory"
I had a rtems_fatal_extension installed, so I don't know. I will
remove it and see what happens.
Aleix
