rtems_dhcp.c: dhcp_task() bug? plus question
Arnout Vandecappelle arnout at mind.be
Mon Nov 3 08:45:46 UTC 2008
On Thursday 30 October 2008 18:00:18 Gene Smith wrote:
> Looking with a debugger, I noticed that dhcp_task(), which I think just
> checks when to do a lease renewal, was exiting the first time it ran.
> The only way it should ever exit is if an event is received from the
> dhcp failsafe code, which I am not running, indicating the interface has
> gone down. In the task, the function rtems_event_receive() would wait
> for a second and return, as it should. But the check was for event_out
> to contain bit RTEMS_EVENT_0. But since no event actually was received
> (it really did time out) the event_out was never set by
> rtems_event_received() and contained a random value.
> The solution I think is to
> 1) Initialize event_out to 0 when it is declared or
> 2) Check the return on rtems_event() !RTEMS_TIMEOUT and exit on that
> condition.
> Right now I am doing the 2nd option.
 Yep that's a bug and a correct fix.
> My question is why does this task poll every seconds? Seems like it
> could be a minute or more since leases are usually in terms of hours, I
> think, and it renews at the half-way point.
 I don't see any real reason to work that way.  When I modified the dhcp_task,
I left that bit as-is to avoid breaking things :-) .  One could argue that
this way, when an error occurs, the DHCP request is repeated every second,
but there are better ways to code that...
 Regards,
 Arnout
Arnout Vandecappelle                               arnout at mind be
Senior Embedded Software Architect                 +32-16-286540
Essensium/Mind                                     http://www.mind.be
G.Geenslaan 9, 3001 Leuven, Belgium                BE 872 984 063 RPR Leuven
LinkedIn profile: http://www.linkedin.com/in/arnoutvandecappelle
GPG fingerprint:  D206 D44B 5155 DF98 550D  3F2A 2213 88AA A1C7 C933
