RTEMS port to Lattice Mico32 (lm32)
    Jukka Pietarinen
    jukka.pietarinen at mrf.fi
    Thu Nov  6 16:10:06 UTC 2008
Hi,
I have started to work towards a RTEMS port to the Lattice Mico32
softcore CPU (lm32). I have built the tools starting with sources from
Lattice which are based on binutils-2.18 and gcc-3.4.4, and replaced the
supplied newlib with newlib-1.16 and RTEMS patches (yes, I know this gcc
version is outdated but unfortunately the lm32 target is not in the FSF
source tree).
The current status is that I am able to run the "hello" application with
a polling console. The RTEMS version I'm working is from CVS, early October.
I ran into a problem with the allocation of workspace and heap. If I use
the shared bootcard.c heap_start is always defined as NULL. Just to get
forward I hard-coded the addresses and sizes for both the workspace and
heap in bootcard.c, but how should the start of heap be really defined?
There seems to be an option of using a unified work area for both
workspace and heap, too.
I'm targeting custom hardware with a ECP2M-20 FPGA, 32 Mbytes of DDR2
memory and 10/100 ethernet.
Thanks,
Jukka
