RTEMS port to Lattice Mico32 (lm32)
Fri Nov 7 15:35:43 UTC 2008
Jukka Pietarinen wrote:
> Hi,
> I have started to work towards a RTEMS port to the Lattice Mico32
> softcore CPU (lm32). I have built the tools starting with sources from
> Lattice which are based on binutils-2.18 and gcc-3.4.4, and replaced the
> supplied newlib with newlib-1.16 and RTEMS patches (yes, I know this gcc
> version is outdated but unfortunately the lm32 target is not in the FSF
> source tree).
:(  I wish vendors would submit their ports.  Altera is in
the same situation with the NIOS 2 tools.
Anyone who can apply pressure to the vendors to submit their
tools should.
> The current status is that I am able to run the "hello" application with
> a polling console. The RTEMS version I'm working is from CVS, early October.
Great!  Hopefully you will be submitting this in the not so
distant future.
Please also write up a chapter for the CPU Supplement to
provide some details on the port.
Was the port hard so far?  Are you using the newlib C library?
> I ran into a problem with the allocation of workspace and heap. If I use
> the shared bootcard.c heap_start is always defined as NULL. Just to get
> forward I hard-coded the addresses and sizes for both the workspace and
> heap in bootcard.c, but how should the start of heap be really defined?
It sounds line you have defined all the required symbols
correctly in your linkcmds but just to double check, this
is the set:
+ WorkAreaBase
+ RamBase
+ RamSize
If so, then by default libbsp/shared/bspgetworkarea.c
sets *heap_start as NULL to indicate that the logic
in libbsp/shared/bootcard.c can select the starting
address for the C Program Heap.  See the method
bootcard_bsp_libc_helper() in bootcard.c.  If you
have heap_start == NULL, then it is free to allocate
memory as it sees fit.
Set a break point at bsp_libc_init and do a back
trace.  That routine is passed the C program heap
start and size.
> There seems to be an option of using a unified work area for both
> workspace and heap, too.
Yes.  It is an application configure time option.  Most
of the tests use a split workspace/C program heap
configuration though.
> I'm targeting custom hardware with a ECP2M-20 FPGA, 32 Mbytes of DDR2
> memory and 10/100 ethernet.
In this case, the C Program Heap should be nearly all of
the 32MB of RAM for most tests.
> Thanks,
> Jukka
> rtems-users mailing list
> rtems-users at rtems.com
