Any Issues Preventing 4.9.1?
Daron Chabot daron.chabot at gmail.com
Wed Nov 12 17:13:01 UTC 2008
Joel Sherrill wrote:
> Hi,
> I just wanted to double check that no one
> was holding a patch or problem that we wanted
> to try to address for 4.9.1.
> Thanks.
I'm doing some testing with 4.9.0 and have found two issues. No
show-stoppers but I thought I'd post my findings.
1) rtems_bsdnet_synchronize_ntp() is broken in 4.9.0. The problem lies
in rtems_bsdnet_ntp.c, CVS version 1.10.6.1. However, I see that things
are fixed with version 1.14 of that file (the "port" problem).
2) Stripping info from binary files produces unusable executables with
gcc-4.3.2 and binutils-2.18: "bsp-post-link" defined in
make/custom/pc386.cfg is the culprit. In particular, the
--remove-section=.rodata option to the $(OBJCOPY) cmd.
Using Qemu, try a simple demonstration (use appropriate paths):
chabotd at opi2043-001--> qemu -no-kqemu -no-reboot -m 128 -boot n -tftp
/opt/rtems/i386-rtems/pc386/lib/rtems-4.9/tests -bootp /hello.exe
-serial stdio
Works fine, right ?
Now, run the command defined by "bsp-post-link" on the executable hello.exe:
chabotd at opi2043-001--> cp
/opt/rtems/i386-rtems/pc386/lib/rtems-4.9/tests/hello.exe /tmp/hello.exe
chabotd at opi2043-001--> cd /tmp
chabotd at opi2043-001--> i386-rtems-objcopy -O elf32-i386
--remove-section=.rodata --remove-section=.comment
--remove-section=.note --strip-unneeded hello.exe hello.nxe
And, now try Qemu using "rtems.nxe":
/tmp -bootp /hello.nxe -serial stdio
qemu: fatal: triple fault
EAX=00000000 EBX=00000000 ECX=00121b7d EDX=00000000
ESI=0011e5c4 EDI=00000004 EBP=00000008 ESP=00121b08
EIP=0000004c EFL=00000002 [-------] CPL=0 II=0 A20=1 SMM=0 HLT=0
ES =0010 00000000 ffffffff 00cf9300
CS =0008 00000000 ffffffff 00cf9e00
SS =0010 00000000 ffffffff 00cf9300
DS =0010 00000000 ffffffff 00cf9300
FS =0010 00000000 ffffffff 00cf9300
GS =0010 00000000 ffffffff 00cf9300
LDT=0000 00000000 0000ffff 00008000
TR =0000 00000000 0000ffff 00008000
GDT=     0011bc70 00000017
IDT=     0011bc90 000007ff
CR0=00050033 CR2=00000000 CR3=00000000 CR4=00000000
CCS=00000000 CCD=00000000 CCO=ADDB
FCW=037f FSW=0000 [ST=0] FTW=00 MXCSR=00001f80
FPR0=0000000000000000 0000 FPR1=0000000000000000 0000
FPR2=0000000000000000 0000 FPR3=0000000000000000 0000
FPR4=0000000000000000 0000 FPR5=0000000000000000 0000
FPR6=0000000000000000 0000 FPR7=0000000000000000 0000
XMM00=00000000000000000000000000000000
XMM01=00000000000000000000000000000000XMM02=00000000000000000000000000000000
XMM03=00000000000000000000000000000000XMM04=00000000000000000000000000000000
XMM05=00000000000000000000000000000000XMM06=00000000000000000000000000000000
XMM07=00000000000000000000000000000000
Aborted
As I implied, omitting the "--remove-section=.rodata" from the
$(OBJCOPY) command *will* produce a functional, stripped executable.
Plus, it only costs 48 bytes :-)
Perhaps someone with more experience can weigh in...
-- dc
