c++ blackfin toolchain
Tue Nov 18 15:11:18 UTC 2008
Ralf Corsepius wrote:
> On Tue, 2008-11-18 at 08:36 -0600, Joel Sherrill wrote:
>> MOLM wrote:
>>> I have just installed toolchain and rtems 4.9 for the bf537 stamp
>>> board, and are able to compile the "hello world" sample - great!
>>> However, is there a reason for the g++ toolchain is missing for the
>>> blackfin architecture? Is it possible to build this support from
>>> source? I am trying to move a C++ application from uClinux environment
>>> to rterms in order to improve realtime response.
>> Ralf should recall if there is a current reason but historically the
>> bfin gcc port didn't build for bfin reliably and C++ rarely built.
> Pardon, but I don't recall the details. IIRC, it had been a mixture of
> "bugs" and "not being supported in GCC" (One detail I recall: issues
> with libssp).
Well together we remember "didn't work at one time so
disabled."
>> Ralf have you checked this recently?
> No. TBD.
>>   Maybe things have improved.
>> You can always build your own toolchain and enable C++.
> Unless GCC rejects a language ;)
If it builds for uCLinux, then it should build for us.
They aren't special. :)
--joel
