c++ blackfin toolchain
Tue Nov 18 17:06:55 UTC 2008
Ralf Corsepius wrote:
>>> On Tue, 2008-11-18 at 08:36 -0600, Joel Sherrill wrote:
>>>> MOLM wrote:
>>>>> I have just installed toolchain and rtems 4.9 for the bf537 stamp
>>>>> board, and are able to compile the "hello world" sample - great!
>>>>> However, is there a reason for the g++ toolchain is missing for the
>>>>> blackfin architecture? Is it possible to build this support from
>>>>> source?
>> Well together we remember "didn't work at one time so
>> disabled."
>>>> Ralf have you checked this recently?
>>> No. TBD.
> Done - gcc-4.3.2/newlib-1.16.0 (aka current rtems-4.10 toolchain
> sources) builds bfin-gcc-c++ without any eye-striking problems[1].
> I am going to add c++ for the bfin for the rtems-4.10-toolchains.
> Ralf
> [1] Of course, this doesn't mean much ;)
If someone can help verify that the latest Skyeye code runs
the RTEMS bfin BSPs correctly, I can then turn on running the
GCC C and C++ tests on this target.
I hadn't turned bfin tool testing on because the bfin skyeye
code still didn't run the BSP out of the box.
--joel
