Who is RobertF?
Robert Fu
robert.fu at live.com
Thu Nov 20 10:24:10 UTC 2008
Hi Jeol,
It's me. Last night I uploaded screen shots while writing/previewing "RTEMS Eclipse Plug-In" wiki page. Although some files were uploaded, error page (HTTP 500 Internal Server Error or Could not create directory) came up for almost every uploading, and later I could not accessthe wiki site.
I developed an Eclipse plug-in for RTEMS (http://www.rtems.com/wiki/index.php/RTEMS_Eclipse_Plug-in). Please take a look. I'm new to RTEMS, and also new to Eclipse plug-in
development. This is the 1st plug-in that I ever developed. So please
be patient if you encounter problems while using it.
While working on the GDB part of the plug-in, I initially used --enable-rdbg inconfigure. Later I found --enable-rtems-debug was mentioned in a wiki page. When I used both --enable-rdbg and --enable-rtems-debug in configure, during startup my application hang at "_HAssert(_Heap_Is_prev_used( next_block ));" in cpukit\score\src\heapsizeofuserarea.c. I went back to use --enable-rdbg. So myquestion is: which configure option should be used to enable remote debugging?
I wish RTEMS had support for modern gigabit ethernet cards such as Realtek RTL8111Cand Intel 82574L. Many new hardware kits only have this kind of gigabit ethernet cards,and without corresponding network driver, it seems that serial port becomes the only supported bi-directional link that can be used to interact with external systems.
Thanks,Robert Fu
> Date: Wed, 19 Nov 2008 11:03:28 -0600> From: joel.sherrill at oarcorp.com> To: rtems-users at rtems.org> Subject: Who is RobertF?> > Hi,> > RobertF has uploaded a lot of interesting pictures> to the wiki lately and I would like to connect an> email address with the work.> > The pictures look like Eclipse with RTEMS awareness.> Hopefully this is something you want to make public> and get more help on.> > Thanks.> > -- > Joel Sherrill, Ph.D. Director of Research & Development> joel.sherrill at OARcorp.com On-Line Applications Research> Ask me about RTEMS: a free RTOS Huntsville AL 35805> Support Available (256) 722-9985> > > _______________________________________________> rtems-users mailing list> rtems-users at rtems.com> http://rtems.rtems.org/mailman/listinfo/rtems-users
_________________________________________________________________
Get more done, have more fun, and stay more connected with Windows Mobile®.
http://clk.atdmt.com/MRT/go/119642556/direct/01/
URL: <http://lists.rtems.org/pipermail/users/attachments/20081120/1c8daefb/attachment.html>
