RES: Who is RobertF?
Wendell Pereira da Silva wendell.silva at compsisnet.com.br
Fri Nov 21 14:01:15 UTC 2008
Hi Robert Fu,
This is just to complement your information.
Here, at COMPSIS (Brazil), our development environment includes VMWare
6.0 playing Fedora 7, RTEMS 4.8.0, Eclipse 3.3 CDT and a customized
(home made) version of SIS (with GPIO emulation with the PC's parallel
port and a GDB Server interface via TCP/IP - which allow us to use both
UARTs to run our protocols). Everything has worked very well since its
implementation (6 month ago). VMWare have worked very well in Windows
Vista 32 in our case. None of our problems (in the beginning) wasn't
regarding to the VMWare.
Att.
Wendell P. Silva.
________________________________
De: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org]
Em nome de Robert Fu
Enviada em: sexta-feira, 21 de novembro de 2008 04:33
Para: daronchabot at gmail.com
Cc: rtems-users at rtems.org
Assunto: RE: Who is RobertF?
Hi Daron,
Thanks for clarify Option --enable-rdbg and --enable-rtems-debug.
The RTEMS version I used is 4.9.0. I'm not sure if the problem has
anything to do with VMWare, or some of my heap configurations
were not right. I'll keep eye on it in the future.
Thanks,
Robert Fu
> From: daronchabot at gmail.com
> Subject: Re: Who is RobertF?
> Date: Thu, 20 Nov 2008 07:10:53 -0600
> To: robert.fu at live.com
> CC: rtems-users at rtems.org
> On 20-Nov-08, at 4:24 AM, Robert Fu wrote:
> > Hi Jeol,
> > It's me. Last night I uploaded screen shots while writing/previewing
> > "RTEMS Eclipse Plug-In" wiki page. Although some files were
uploaded,
> > error page (HTTP 500 Internal Server Error or Could not create
> > directory)
> > came up for almost every uploading, and later I could not access
> > the wiki site.
> > I developed an Eclipse plug-in for RTEMS (http://www.rtems.com/wiki/
> > index.php/RTEMS_Eclipse_Plug-in).
> > Please take a look. I'm new to RTEMS, and also new to Eclipse
plug-in
> > development. This is the 1st plug-in that I ever developed. So
please
> > be patient if you encounter problems while using it.
> Well done! Thanks for your contribution.
> However, as Sebastian pointed out the plugin is not accessible on the
> FTP site. I'd really like to check out your work.
> > While working on the GDB part of the plug-in, I initially used --
> > enable-rdbg in
> > configure. Later I found --enable-rtems-debug was mentioned in a
> > wiki page.
> > When I used both --enable-rdbg and --enable-rtems-debug in
> > configure, during startup
> > my application hang at "_HAssert(_Heap_Is_prev_used
> > ( next_block ));" in
> > cpukit\score\src\heapsizeofuserarea.c. I went back to use --enable-
> > rdbg. So my
> > question is: which configure option should be used to enable remote
> > debugging?
> Option --enable-rdbg is the one to use to enable remote debugging.
> Option --enable-rtems-debug activates some instrumentation within
> RTEMS itself (malloc statistics at least...).
> I use both switches simultaneously and have not seen the problem you
> reported. What version of RTEMS are you using ??
> -- dc
> rtems-users mailing list
> rtems-users at rtems.com
Get more done, have more fun, and stay more connected with Windows
Mobile(r). See how. <http://clk.atdmt.com/MRT/go/119642556/direct/01/>
URL: <http://lists.rtems.org/pipermail/users/attachments/20081121/52792e6a/attachment.html>
