plugin mods
Mon Nov 24 10:00:59 UTC 2008
Ralf Corsepius wrote:
> On Mon, 2008-11-24 at 10:10 +0100, Sebastian Huber wrote:
>>  I set the following environment variables before the eclipse
>> startup:
> Hmm, I haven't followed your efforts, but there are some details, which
> I feel, can't be right
>> RTEMS_TARGET_TOOL_DIR=/opt/rtems-4.9/i386-rtems4.9
> No idea why you need this - You should not have to.
>> RTEMS_TARGET_CPU_GCC_LIB_DIR=/opt/rtems-4.9/lib64/gcc/i386-rtems4.9/4.3.0/mpentiumpro
> And this one is definitely wrong. This directory is a gcc internal
> implementation detail you must not have to care about. If you have to,
> something is broken with your approach.
This is work in progress.  The final version will not contain such things.
Sebastian Huber, Embedded Brains GmbH
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
PGP     : Public key available on request
