plugin first steps
Daron Chabot daronchabot at gmail.com
Mon Nov 24 16:42:02 UTC 2008
Joel Sherrill wrote:
>>> Although I don't know how actually Sebastian plan to do it, I think
>>> if we can
>>> automatically extract settings/configurations from Makefiles generated
>>> by configure process, it's an improvement over the current one
>>> since it'd
>>> require less user input.
>> That approach implies some type of parser is required. I'm sure
>> Sebastian will communicate his ideas here as soon as he's able.
> I have attached a Makefile which shows how to extract
> a few of the key variables.  It might help as an example.
Thanks, Joel.
> Long term, it would be better to generate the Eclipse
> file and just install it along with the BSP.  So try to keep
> this part of the kit very small so it is easy to grab from
> the RTEMS BSP install.
Not sure what you mean by "...generate the Eclipse file"... Could you
please clarify ?
If we do things properly, RTEMS should know nothing of Eclipse (i.e.
zero coupling from RTEMS-->Eclipse).
-- dc
