4.5.1pre3 installation issue
Ricardo Derbes
rderbes at invap.com.ar
Fri Nov 28 17:57:14 UTC 2008
Hello.
When trying to build rtems-4.5.1pre3 I get the following error:
a - ../../sapi/src/o-optimize/rtemsapi.o
/opt/rtems/sparc-rtems/bin/ranlib o-optimize/librtems.a
# cd ../../../../../.. ; \
/bin/sh ../../../../../../tools/cpu/generic/size_rtems erc32 o-optimize \
>../../../../../../erc32/lib/sizeinfo.txt
make[5]: *** [o-optimize/librtems.a] Error 1
make[5]: Leaving directory `/home/rmd/rtems-4.5.1/tools/build-4.5.1-pre3/sparc-rtems/c/erc32/exec/wrapup/rtems'
make[4]: *** [all-recursive] Error 1
make[4]: Leaving directory `/home/rmd/rtems-4.5.1/tools/build-4.5.1-pre3/sparc-rtems/c/erc32/exec/wrapup'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/home/rmd/rtems-4.5.1/tools/build-4.5.1-pre3/sparc-rtems/c/erc32/exec'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/rmd/rtems-4.5.1/tools/build-4.5.1-pre3/sparc-rtems/c/erc32'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/rmd/rtems-4.5.1/tools/build-4.5.1-pre3/sparc-rtems/c'
make: *** [all-recursive] Error 1
I have already downloaded and installed the cross-compiling toolchain :
rtems-base-binutils-2.10-3.i386.rpm
rtems-base-gcc-gcc2.95.3newlib1.8.2-450_1.i386.rpm
rtems-base-gdb-5.0-4.i386.rpm
sparc-rtems-binutils-2.10-3.i386.rpm
sparc-rtems-gcc-gcc2.95.3newlib1.8.2-450_1.i386.rpm
sparc-rtems-gdb-5.0-4.i386.rpm (this one has a trouble with libncurses.so.4)
in /opt/rtems
My development machine is a i686 with a clean Fedora 9 installation (gcc-4.3.0, binutils-2-18.50)
The rtems was successfully configured with:
../rtems-4-5-1pre3/configure --target=sparc-rtems --enable-rtemsbsp="erc32" --enable-cxx --enable-posix --enable-tests \
--enable-rdbg --prefix=/opt/rtems-4.5.1pre3
in a build directory
What can I do to install it? I need this version of rtems
Thank you
URL: <http://lists.rtems.org/pipermail/users/attachments/20081128/e74415e3/attachment.html>
