Any Issues Preventng 4.9.1
Michael South
msouth at msouth.org
Sat Nov 29 11:07:25 UTC 2008
Typographical correction to the patches. It's the _8254_ (timer), not
the _8259_ (PIC).
> OK, I've got it done. Instead of using HPET chips (I don't have ready
> access to such a motherboard), I used the TSC register available on
> Pentium-class CPUs. There are some pluses and minuses to that; high
> precision, _if_ the BIOS doesn't alter the clock frequency for thermal
> or power saving reasons.
> Anyway, it's all attached for your perusal.
> Summary of results:
> Six varieties of code tested:
> 1) Unmodified ckinit.c
> 2) Un-modified ckinit.c, configured with
> USE_TICKS_FOR_CPU_USAGE_STATISTICS=1
> 3) Just commented out I/O
> 4) Re-worked ckinit.c, with new switch CLOCK_DRIVER_USE_TSC = 1.
> It uses the TSC register on Pentium-class processors.
> 5) Re-worked ckinit.c, with new switch CLOCK_DRIVER_USE_8529 = 1.
> Equivalent to unmodified ckinit.c.
> 6) Re-worked ckinit.c, with neither ..._USE_TSC nor ..._USE_8529
> defined. Equivalent to (3).
> Test box is a 500 MHz AMD K6-2.
> Context switches nSec per switch
> per tick (1 KHz)
> (1) 153 6,525
> (2) 1,582 632
> (3) 1,025 976
> (4) 939 1,065
> (5) 153 6,524
> (6) 1,117 895
Michael South
Type: application/x-compressed-tar
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20081129/736799ba/attachment.bin>
