Any Issues Preventing 4.9.1?
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Nov 19 14:42:11 UTC 2008
Michael South wrote:
> Getting really bad context switch times on pc386 when
> RTEMS_ENABLE_NANOSECOND_CPU_USAGE_STATISTICS is enabled. (Something
> like a factor of ten on one of my desktops). I posted a discussion note
> on the 4.9.0 release Wiki page.
I just saw the talk page this morning. Can you try a few
things and let's see where that takes us.
+ Send me your test program so I can check it on other
targets.
+ Temporarily change bsp_clock_nanoseconds_since_last_tick()
in /c/src/lib/libbsp/i386/pc386/clock/ckinit.c to return 0 and
not touch the hardware. Rerun and report results.
+ If above shows problem, provide alternative code that uses
the method you mention in the Wiki Talk page.
+ If we can't dynamically figure out if the alternative method
works, then we can make it a BSP configure time option
like using COM1 as console (see configure.ac in the pc386
directory). If you can provide the code, I can fix the configure.ac
if this turns out to be needed.
I have had concerns that the timespec math is expensive but
never thought that slow clock hardware would be an issue.
> Michael South msouth at msouth.org
> rtems-users mailing list
> rtems-users at rtems.com
