Are task priorities relative?
Gene Smith
gds at chartertn.net
Thu Nov 20 00:50:49 UTC 2008
Yes, they are relative. My timing problem was due to another reason that
only appeared after 10 min (due to assigning a int to a short). Task
prio works they way I thought.
-g
Gene Smith wrote:
> Maybe I am (again) confused but it seems like I see different timing
> when my tasks are like this:
> TaskA = prio 150 (rtem dhcp task)
> TaskB = prio-150 (my app task)
> TaskC = prio-151 (my Init/app task, UI1)
> compared to
> TaskA = prio-119 (rtems_dhcp_task)
> TaskB = prio-119 (my app task)
> TaskC = prio-120 (my Init/app task, UI1).
> In both case I have other system tasks all at prio 100:
> ntwk,ENrx,ENtx,TNTD,pty0 (seen with shell cmd "task").
> I would think that since the relative priorities of TaskA, B and C are
> the same in both cases they should act exactly the same timing wise.??
> dhcp is the standard rtems task. UI1 just runs in a continuous loop.
> TaskB only blocks on select() for up to 1 tick. No rtems messages or
> events are passed between the tasks.
> -gene
