plugin first steps
Daron Chabot
daronchabot at gmail.com
Sat Nov 22 21:00:37 UTC 2008
On 22-Nov-08, at 2:40 PM, Robert Fu wrote:
> Hi Daron,
> > However, upon closer analysis, it became clear that in order to
> > maintain a useful degree of independence from the RTEMS build-system
> > and maximum flexibility, the Managed Build approach is *the* way
> to go.
> Agreed. I also thought about whether we need support "Standard
> Makefile"
> type of project.
> Beside the CVS repo you mentioned earlier, the official CDT release
> also come
> with CDT source code, and being able to browsing and debugging/
> tracing into
> CDT source code helped me in the development.
> If you and Sebastian send me the error messages, commands invoked and
> the Makefile generated for the HelloWorld example on your system
> (via private
> email, not the whole list), perhaps I can better understand what
> problems
> you're currently facing on your system.
Sure. But, I think most of the problems I've seen are due to hard-
coded command-names and supported-OS types.
I'm making some notes as I go, so I'll report back later when I've
found out more. Probably tonight or tomorrow...
> > From: daronchabot at gmail.com
> > Subject: Re: plugin first steps
> > Date: Sat, 22 Nov 2008 13:16:49 -0600
> > To: robert.fu at live.com
> > CC: sebastian.huber at embedded-brains.de; rtems-users at rtems.org
> > On 22-Nov-08, at 3:38 AM, Robert Fu wrote:
> > > For the "first steps" type of references, there is also another
> > > place contains
> > > more detailed information: "Managed Build System Extensibility
> > > Document"
> > > (mentioned in referrence section in my previous email) contains a
> > > section called
> > > "Tutorial: An Example Tool Integration". It worked well for me.
> The
> > > initial
> > > version of the plug-in was built upon what I got after following
> > > the tutorial
> > > step by step.
> > > Somebody said "Managed Build System Extensibility Document" is the
> > > bible
> > > for CDT plug-in development, and I believed it. In fact this
> > > document plus
> > > "What's New in CDT Build System 4.0" are the only 2 documents that
> > > guided me for the developement of initial RTEMS plug-in.
> > Yah, I've been through the "MBS Extensibility" doc, and it *is* the
> > "bible" for CDT plugin development. But, there are other good
> sources
> > too, the CDT sources being an example. Another is the CDT extension
> > point reference docs:
> > http://help.eclipse.org/help33/index.jsp?topic=/
> > org.eclipse.cdt.doc.isv/reference/extension-points/index.html
> > Although these refer to eclipse 3.3, they are still very much
> > relevant to the CDT as found in eclipse 3.4.
> > > Although I don't know how actually Sebastian plan to do it, I
> think
> > > if we can
> > > automatically extract settings/configurations from Makefiles
> generated
> > > by configure process, it's an improvement over the current one
> > > since it'd
> > > require less user input.
> > That approach implies some type of parser is required. I'm sure
> > Sebastian will communicate his ideas here as soon as he's able.
> > Only a couple of years ago, the CDT had two types of projects:
> > Managed Build and Standard Makefile. Both are still present, only in
> > a more refined form. Managed build projects construct Makefiles
> > automatically, while Standard Makefile projects simply rely on the
> > user to provide a (Makefile-based) build system.
> > The RTEMS-Eclipse plugin I was designing would utilize the RTEMS
> > makefile templates, Makefile.leaf, Makefile.lib, and Makefile.dir
> > (found in ${RTEMS_INSTALL_LOCATION}/make/Templates), *in conjuction*
> > with user-provided values like executable name, etc.
> to go.
> > > One other improvement I can see is to make it work on Linux and
> Mac.
> > > It seems we 3 have right mix of environments: I have Windows one,
> > > Sebastian
> > > has openSuSE 10.3 env and you have Mac env.
> > Having the plugin work across the 3, main OSes is not just an
> > improvement, it's a *necessity * :-)
> > Of course, we should strive for OS-independence as much as
> possible...
> > I would also lump RTEMS target arch and BSP selection as
> necessities.
> > > I assume that we cannot get all we want in one shot, so one of
> many
> > > possible
> > > ways to move forward is:
> > > 1. Make the 1st version work in Linux and Mac; Once it works in
> one
> > > OS, re-test
> > > it in the other OS until we get one version that works in each
> > > of the 3 OS. We
> > > then use it as a comman base for further refinement.
> > > 2. Add new improvements one by one. After one new feature works in
> > > one OS,
> > > re-test the new plug-in in the other OS. We go through this
> > > iterative process
> > > until we think we have all necessary features.
> > Yes. An iterative development scheme is the only way to go.
> > We need to get a solid base to build upon. First focusing on the
> > basic toolchain elements: assembler, c/c++ compiler & linker,
> > archiver. Debugger and Launch configs are almost as important.
> But we
> > have to be able to build something to run and debug first :-)
> > I'm still studying your plugin trying to get up to speed... thanks
> > again.
> > > > Subject: plugin first steps
> > > > Date: Fri, 21 Nov 2008 21:05:17 -0600
> > > > Robert,
> > > > Thanks for your contribution. It looks like a good place to
> start.
> > > > I sent the link below to Sebastian in an earlier email.
> > > > If you have not already done so, I recommend checking out the
> cdt-
> > > all
> > > > CVS module from the Eclipse repo. You can find directions here:
> > > > http://wiki.eclipse.org/Getting_started_with_CDT_development
> > > > The best place to learn how things work is the reference
> > > > implementations contained in the "cdt-all" CVS module.
> > > > If you and Sebastian have no objections, I'd like to remove the
> > > > unused library dependencies from the plugin's ".settings" file,
> > > > partly to see if I can commit to the RTEMS cvs repo and
> partly to
> > > > clean things up a bit.
> > > > Those dependencies are:
> > > > 1) org.eclipse.cdt.core.lrparser_5.0.1.200809120802.jar
> > > > 2) org.eclipse.cdt.core.parser.upc_5.0.0.200809120802.jar
> > > > -- dc
> > > > _______________________________________________
> > > > rtems-users mailing list
> > > > rtems-users at rtems.com
> > > > http://rtems.rtems.org/mailman/listinfo/rtems-us
> > > Get more done, have more fun, and stay more connected with Windows
> > > Mobile®. See how.
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
> Proud to be a PC? Show the world. Download the “I’m a PC” Messenger
> themepack now. Download now.
