plugin mods
Ralf Corsepius
ralf.corsepius at rtems.org
Mon Nov 24 09:54:29 UTC 2008
On Mon, 2008-11-24 at 10:10 +0100, Sebastian Huber wrote:
> I set the following environment variables before the eclipse
> startup:
Hmm, I haven't followed your efforts, but there are some details, which
I feel, can't be right
> RTEMS_TARGET_TOOL_DIR=/opt/rtems-4.9/i386-rtems4.9
No idea why you need this - You should not have to.
> RTEMS_TARGET_CPU_GCC_LIB_DIR=/opt/rtems-4.9/lib64/gcc/i386-rtems4.9/4.3.0/mpentiumpro
And this one is definitely wrong. This directory is a gcc internal
implementation detail you must not have to care about. If you have to,
something is broken with your approach.
Ralf
