plugin first steps
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Nov 24 16:52:18 UTC 2008
Daron Chabot wrote:
> Joel Sherrill wrote:
>>>> Although I don't know how actually Sebastian plan to do it, I think
>>>> if we can
>>>> automatically extract settings/configurations from Makefiles generated
>>>> by configure process, it's an improvement over the current one
>>>> since it'd
>>>> require less user input.
>>> That approach implies some type of parser is required. I'm sure
>>> Sebastian will communicate his ideas here as soon as he's able.
>> I have attached a Makefile which shows how to extract
>> a few of the key variables. It might help as an example.
> Thanks, Joel.
>> Long term, it would be better to generate the Eclipse
>> file and just install it along with the BSP. So try to keep
>> this part of the kit very small so it is easy to grab from
>> the RTEMS BSP install.
> Not sure what you mean by "...generate the Eclipse file"... Could you
> please clarify ?
It seems like you are working to extract information
from the RTEMS Application Makefiles and generate
some configuration information for Eclipse. Chris
has been working to eliminate them in favor of autoconf
for the external examples.
Couldn't the same information be directly generated
by RTEMS?
> If we do things properly, RTEMS should know nothing of Eclipse (i.e.
> zero coupling from RTEMS-->Eclipse).
Keep going the way you are. When it all works we can
step back and see what is the right thing long term
from a very high level view. :-D
Keep going. Make it work first.
> -- dc
