RTEMS for bare-bones ARM
Web.POP
Marc.Enzmann at web.de
Thu Nov 27 18:35:50 UTC 2008
>> .../newlib/libc/include/sys/dirent.h:10:2: error: #error
>> "<dirent.h> not supported"
> That looks like you are getting the generic dirent.h
> in newlib, not the RTEMS specific one from another
> subdirectory.
> It would help to know versions, patches and how far you got.
> I build Ada for GCC 4.3.x and SVN trunk regularly so something
> is just slightly out of whack.
Right, of course.
I am using the following
- autoconf-2.62 (no patches)
-automake-1.10.1 (no patches)
-binutils2.18 (patch binutils-2.18-rtems4.9-20080211.diff)
-gcc-4.3.2 (patches gcc-core-4.3.2-rtems-4.9-20080828 and
gcc-4.3.2-20080910.diff )
-newlib-1.16.0 (patches newlib-1.16.0-rtems4.9-20080827.diff)
now, the host.compiler is gcc-4.3.1 (20080507)
I compiled and installed autoconf, automake and binutils.
Then I compiled the C Cross-Compiler and Newlib.
The process stops, when I try to build the non-multilib C and Ada
Cross Compiler.
I had to add --disable-libsp to the configure commmand for the C
Cross-Compiler and
the C / Ada Cross-Compiler, so that the build of the first one
proceeded well.
Thanks for your support!
Cheers,
Marc
URL: <http://lists.rtems.org/pipermail/users/attachments/20081127/0f36528b/attachment-0001.html>
