POSIX FIFO/pipe
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Oct 1 14:00:24 UTC 2008
Wei Shen wrote:
> Hi,
> My patch should against which version?
> 4.8.99.0 checked out by: "cvs -d
> :pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co -P rtems" ?
The CVS head is always preferred for functional
patches.
--joel
> BR,
> Wei
> On 9/2/08, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>> Wei Shen wrote:
>>> Hi all,
>>> I think I am close to finishing my work on POSIX FIFO/pipe. I ported
>>> the test cases in LTP (Linux Test Project) to test my code, seems that
>>> all cases can be passed.
>>> So, how can I submit my code?
>> If the patch is small, you can post it to the list for others to see.
>> But if it is too large, you can send it to me directly.
>> Whether I merge it before or after making a 4.9 branch is unknown
>> at this point.
>>> Regards,
>>> Wei
>> Joel Sherrill, Ph.D. Director of Research & Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
