Problem with spi-sd-card.c (rtems-4.9.0)
Robert S. Grimes rsg at alum.mit.edu
Fri Oct 3 00:59:11 UTC 2008
Joel Sherrill wrote:
> I meant did the BSP allocate the memory to RTEMS and
> the C library in a reasonable way.
I'm not sure how to check this.  Are you referring to your email of 9/15
regarding the "Change Impacting All BSPs"?
Some evidence (my full application runs on 4.9.0) points to this not
being a problem, and I don't see how I could be using more memory for
this simple, stripped-down SD memory test program - all I'm trying to do
now is get the driver to load properly.  Still, I would be happy to
check on this if you give me a little more guidance.
>>     #define CONFIGURE_INIT_TASK_STACK_SIZE                (10*1024)
> Is it still before your include of <rtems/confdefs.h>?
Yes.
I probably won't have much time on this until next Wednesday, but I
might be able to put in a couple hours tomorrow - will update when I can.
Thanks, Joel,
-Bob
>> I doubled it to 20k, and it worked - once.  I was about to send this,
>> then I decided I should see if that fixed the second issue, and now it
>> (still) doesn't work!  I even  went to 40k, and it still exhibits both
>> issue 1 and 2.  But anyway, I don't think it is the stack..
>> So, I'm still stuck with all three issues...
>> -Bob
>>>> Seems I've moved backwards from last week.  I switched to 4.9.0, and
>>>> that seemed fine - until I returned to the SD card driver.  I can't
>>>> even
>>>> get the basic card id functions to work - it fails before then.  Here
>>>> are my (current) problems:
>>>> 1. In spi-sd-card.c, sd_card_driver_init, sd_card_driver_get_entry
>>>> fails
>>>> to return pointer to driver.  Specifically, X_get_entry returns an
>>>> incorrect value (0x51xxxx, for example, when it should be 0x48xxxx
>>>> - the
>>>> point of these addresses is only to point out the issue).  Then, the
>>>> following call to CHECK_RVSC blasts the local variable e, setting
>>>> it to 2!
>>>> 2. If I manually correct (in the debugger) the value, when later a
>>>> call
>>>> to rtems_io_register_driver is made, the sd_card_disk_ops table
>>>> only has
>>>> an entry for the initialization_entry; all others are 0.
>>>> 3. Finally, the card never leaves the "busy" state, in that the output
>>>> line is always low.
>>>> 4. I haven't noticed a CMD0 being sent to the card with the CS low;
>>>> this
>>>> seems to be needed to switch the card to SPI mode.  Am I missing
>>>> something?
>>>> Any ideas?
>>>> -Bob
>>>> P.S. I'm using the powerpc/virtex BSP, and the virtex SPI functions
>>>> seem
>>>> to be called correctly, and the SPI signals at the card seem correct.
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.com
>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>    Support Available             (256) 722-9985
