Network problem on ARM
Fri Oct 10 07:28:37 UTC 2008
Gene Smith wrote:
> Would like to know how you ultimately fix this. I may have the same
> problem if I ever optimize my driver to have the DMA drop the received
> packets directly in the mbufs.
I increment now the cluster data start address by two bytes and it works
fine:
static struct mbuf *lpc24xx_eth_new_mbuf( struct ifnet *ifp)
  struct mbuf *m = NULL;
  MGETHDR( m, M_DONTWAIT, MT_DATA);
  if (m != NULL) {
    MCLGET( m, M_DONTWAIT);
    if (IS_FLAG_SET( m->m_flags, M_EXT)) {
      /* Set receive interface */
      m->m_pkthdr.rcvif = ifp;
      /* Adjust by two bytes for proper IP header alignment */
      m->m_data = mtod( m, char *) + 2;
      return m;
    } else {
      m_freem( m);
  return NULL;
Sebastian Huber, Embedded Brains GmbH
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
PGP     : Public key available on request
