make rtems problem
Ralf Corsepius ralf.corsepius at rtems.org
Wed Oct 15 05:33:46 UTC 2008
On Wed, 2008-10-15 at 09:44 +0800, 许加波 wrote:
> Hi all!
> when I make rtems 4.9.0(release) on the Fedora 4 system,
Current version of Fedora is Fedora 9.
Fedora 4 is outdated, discontinued, dead for quite some time. I would
strongly recommend you to upgrade.
>  I use the tools as follow:
> autoconf 2.62
> automake 1.10.1
> binutils 2.18
> gcc 4.3.2 for C/C++ with newlib 1.16.0
> gdb 6.8
Which versions of the rtems chain do you have installed?
> I met a problem as follow:
>  i386-rtems-gcc
This is not an official rtems4.9 toolchain.
>  --pipe -B../../../../../.././lib/ -B../../../../../.././pc686/lib/ -specs bsp_specs -qrtems -isystem
> ../../../../../.././pc686/lib/include  -DASM -mtune=pentiumpro -O2 -g -o start.o -c ../../../../../../../../rtems-
> 4.9.0/c/src/lib/libbsp/i386/pc386/start/start.S
> i386-rtems-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././pc686/lib/ -specs bsp_specs -qrtems -isystem
> ../../../../../.././pc686/lib/include  -DASM -mtune=pentiumpro -O2 -g -isystem ../../../../../.././pc686/lib/include -
> DHEADERADDR=0x00097E00 -o start16.o -c ../../../../../../../../rtems-4.9.0/c/src/lib/libbsp/i386/pc386/start/start16.S
> i386-rtems-ld -N -T ../../../../../../../../rtems-4.9.0/c/src/lib/libbsp/i386/pc386/startup/linkcmds -Ttext 0x00097C00 -e start16
> -nostdlib \
>   --oformat=elf32-i386 \
> -o start16-elf32.o start16.o
> i386-rtems-ld:../../../../../../../../rtems-4.9.0/c/src/lib/libbsp/i386/pc386/startup/linkcmds:100: syntax error
> gmake[7]: *** [start16-elf32.o] error 1
> gmake[7]: Leaving directory `/usr/rtems/rtems-build/i386-rtems/c/pc686/lib/libbsp/i386/pc386'
> gmake[6]: *** [all-recursive] error 1
> gmake[6]: Leaving directory `/usr/rtems/rtems-build/i386-rtems/c/pc686/lib/libbsp/i386/pc386'
> gmake[5]: *** [all-recursive] error 1
> gmake[5]: Leaving directory `/usr/rtems/rtems-build/i386-rtems/c/pc686/lib/libbsp/i386'
> gmake[4]: *** [all-recursive] error 1
> gmake[4]: Leaving directory `/usr/rtems/rtems-build/i386-rtems/c/pc686/lib/libbsp'
> gmake[3]: *** [all-recursive] error 1
> gmake[3]: Leaving directory `/usr/rtems/rtems-build/i386-rtems/c/pc686/lib'
> gmake[2]: *** [all-recursive] error 1
> gmake[2]: Leaving directory `/usr/rtems/rtems-build/i386-rtems/c/pc686'
> gmake[1]: *** [all-recursive] error 1
> gmake[1]: Leaving directory `/usr/rtems/rtems-build/i386-rtems/c'
> gmake: *** [all-recursive] error 1
> [root at localhost rtems-build]#
> It look up as a link error ,but I don't know how to figure out the problem and solve it, please help me, any answer will be appreciated.
You likely are using an incompatible version of binutils.
Ralf
