rtems_task_resume within ISR
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Oct 16 21:12:54 UTC 2008
Tobias Schoofs wrote:
> Hi,
> I want an ISR to activate an error handler process on certain faults. I
> assumed that the following simple code would activate the error handler
> (which is the process with the highest priority, but normally suspended)
> AFTER the completion of the ISR:
> rtems_isr fault(rtems_vector_number vector) {
> rtems_task_resume(eh_id); // eh_id is the error handler
> /* do some other stuff */
> return;
> But it seems that the error handler (eh_id) becomes immediately ready
> and starts execution BEFORE the ISR termates. Is there anything wrong
> with my code?
Did you install this as an RTEMS ISR or a raw ISR attached
directly to the hardware vector?
> Thanks,
> Tobias
> rtems-users mailing list
> rtems-users at rtems.com
